2009 350z. Do I need cap for TPMS to work?
Old Oct 17, 2009 | 11:42 AM
bartturner2's Avatar
bartturner2
Default 2009 350z. Do I need cap for TPMS to work?
I just purchased a 2009 350z. Love, love the car. But it came with only three of the tire valve caps. One is missing. Plus the check air pressure light is on. Do I need a cap to make the light go out? Is the cap special? The others look to just be a metal cap. Thanks for any help!
Old Oct 17, 2009 | 11:50 AM
Entaille's Avatar
Entaille
wat? your tire pressure monitoring system light is on? have you checked the psi in your tires? are you saying a cap is just missing from one the valve stems? that will not have any impact .. now if its missing the entire TPMS sensor, thats a different story.
Old Oct 17, 2009 | 12:43 PM
JEKL's Avatar
JEKL
No, the cap will not make a difference. Make sure all 4 tires are filled to the proper PSI. You might need to drive around on them for a while to make the light go out.
Old Oct 17, 2009 | 02:53 PM
ThePistonDoctor's Avatar
ThePistonDoctor
Yeah mine has been stock on for a day or so from time to time. Just make sure the pressure is right and drive for a couple days, it should go off.
BTW I'm assuming you meant a 370Z lol
Old Oct 17, 2009 | 02:54 PM
RandyK1's Avatar
RandyK1
2009 350Z?????? Maybe a 2008 350Z or a 2009 370Z
Old Oct 17, 2009 | 03:05 PM
JEKL's Avatar
JEKL
2009 350Z Roadster?
Old Oct 17, 2009 | 03:14 PM
MDHRZ's Avatar
MDHRZ
Yes, there is a 2009 350Z roadster. The tires are never inflated all the way when they are shipped. Just check the PSI and fill your tires as needed. Steal a cap from another car. Done.
Old Oct 17, 2009 | 03:52 PM
Swimminggerman's Avatar
Swimminggerman
we have 09 350's ??? for real?
Old Oct 17, 2009 | 04:16 PM
JEKL's Avatar
JEKL
Yup, but only in the Roadster. The 370Z Roadster will be a '10
Old Oct 17, 2009 | 04:32 PM
albaugh81's Avatar
albaugh81
Just get another cap and stick with the plastic valve caps.
Old Oct 17, 2009 | 06:24 PM
carbon z's Avatar
carbon z
The tire air sensor is mounted on the inside of the wheel. If you ever upgrade the wheels on your car, the sensors will need to be moved to the new wheels. Check the owners manual for information on the tire monitoring system.
Old Oct 17, 2009 | 07:42 PM
Kuhan's Avatar
Kuhan
Yes, there are 09 350z roadsters!
Check your tire pressure on your 4 tires plus the spare tire. Should be 35 psi on 4 tires and 60 psi (?) on the spare.
If the light is still on, then reset it by disconnecting the negative on the battery for 5 min (and turn the headlights on for a few min) and then turn off the headlights and re-connect the negative back on the battery.
Old Oct 17, 2009 | 08:46 PM
rtiid22's Avatar
rtiid22
...turn on the headlights without a battery ground?? would that even work?
Old Oct 18, 2009 | 08:04 AM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
No
All you have to do is drive the car, light will go out if all tire pressures are good and everything is working correctly.
Seeing as one cap is missing and that tire happens to be low also I would suspect something in the tire causing the leak.
Old Oct 18, 2009 | 11:18 AM
rob6118's Avatar
rob6118
Do you seriously not know how to discharge the ECM's memory???
He's not saying it to get the headlights on (the battery is disconnected). By turning the headlights on you discharge the battery backup in the ECM of the car thereby resetting error codes.
Old Oct 18, 2009 | 12:22 PM
Spddracer's Avatar
Spddracer
Turning on the headlights without the main battery connected will do absolutely nothing.
350Z_Al
Oct 29, 2020 07:44 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Dymsi
Sep 29, 2015 11:32 AM
