315 possible with a a 1 inch pull
Old Oct 20, 2009 | 05:59 PM
Mamounas123's Avatar
Mamounas123
Default 315 possible with a a 1 inch pull
Im getting the Ings body kit and fenders installed on my car. I also had my quarters pulled one inch. You guys think its possible to fit a 315 in there. I currently have the volk gt-v 10.5 inch with a +19 offset but might be getting a little widers wheels as i think a 315 is too big on a 10.5. any suggestions are welcomes thanks.
Old Oct 20, 2009 | 08:11 PM
M3ANMACHINE's Avatar
M3ANMACHINE
Why exactly do you want to run 315's?
295 or 305 would work fine...
Old Oct 20, 2009 | 08:13 PM
eltness350's Avatar
eltness350
The Untouchable
i have 305's on a 10inch wheel....315's will fit fine u just have to take in consideration ur offset...if the car is lowered...etc...
Old Oct 20, 2009 | 08:18 PM
M3ANMACHINE
P.S. Unless you're going FI, 315 is wayy overkill!
Old Oct 20, 2009 | 08:27 PM
2k6-z33's Avatar
2k6-z33
Old Oct 20, 2009 | 08:42 PM
haeshik's Avatar
haeshik
^+10000000000000000
Old Oct 20, 2009 | 09:00 PM
jbaker1121's Avatar
jbaker1121
but they would look sexy
Old Oct 21, 2009 | 03:45 AM
Mamounas123
so 315/30/19 would fit on the 10.5 inch with 19 + offset?
Old Oct 21, 2009 | 05:41 AM
zerafian's Avatar
zerafian
No I dont think so...well what is your camber like, -4 to -6?
Old Oct 21, 2009 | 06:58 AM
jperleon's Avatar
jperleon
im running a toyo 315/25 on my 10.5 rim. Fits Perfect!
Old Oct 21, 2009 | 08:11 AM
terrasmak's Avatar
Is it a widebody kit? You said something about fenders!
Old Oct 21, 2009 | 08:13 AM
zerafian's Avatar
zerafian
whats your offset and camber? either close to +30 or hella negative camber. These number are important when saying you run 315s
Old Oct 21, 2009 | 08:25 AM
jperleon's Avatar
jperleon
actually i think it is close to +30. honestly cant remember what my offset is.
Old Oct 21, 2009 | 12:09 PM
scotts300's Avatar
scotts300
315 is 10mm too big for a 10.5" wheel, but can be done. With a 1" pull and appropriate wheels/offset, a 315 can absolutely be done. We run 305/30/19s on 19x10.5s without issue, so if we added a 1" pull that would allow 25mm more or rubber to the outside, which clearly falls within the range you are looking at.
Old Oct 21, 2009 | 12:12 PM
M3ANMACHINE
And you'd get like 10mpg if you're not FI...
Old Oct 21, 2009 | 04:59 PM
TimeAttkZ's Avatar
TimeAttkZ
350ZEEEEE is right. 315 is absolutley overkill unliss your pushing some BIG power.
But will it fit you ask...?
I am running 305's in the rear on a 10.5 wheel and Im pretty slammed. My fenders are rolled and slightley pulled and the 305 sits perfectly flush with no rubbing really. If your drop is conservative and you have some negative camber dialed in you might be able to fit the 315. Would it be a optimum fit for a 10.5 wheel ? Absolutley not, the 305's are the widest I would go on a 10.5.
Old Oct 22, 2009 | 05:57 AM
duro78's Avatar
duro78
Are you doing it just to say your running 315? Even if you double your whp you wouldnt really need it.. It would just be a waste and also consider the much higher cost everytime you replace thm
sherm
Apr 11, 2020 05:21 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
