Rays Track V2 on an 03 Touring?
Old May 12, 2010 | 08:31 AM
confusa's Avatar
confusa
Default Rays Track V2 on an 03 Touring?
Would I experience any issues with putting a set of Rays V2 from a later model Track or Grand Touring on an 03? I know the offset is the same, but the fronts are +1" and the rears are +2". And the rears are also 19" instead of 18".
Old May 12, 2010 | 10:32 AM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old May 12, 2010 | 10:46 AM
confusa's Avatar
confusa
Yeah, I was going to do that route for sure. I was more so hoping someone had actually put the wheels on their earlier model Z and could relate their experiences.
Old May 12, 2010 | 10:55 AM
terrasmak's Avatar
Wheels don't cause any problems , tires do. Read the top 100 questions before you post again.
Old May 12, 2010 | 11:03 AM
confusa's Avatar
confusa
Nope, read that already. I was going to be using the stock size tires that come with the rims to not screw with the VDC:
Front
Offset: +30mm
Weight: 21 lbs 4 oz
Tire: 245/40/18
Rear
Offset: +30mm
Weight: 29 lbs 8 oz
Tire: 265/35/19
Old May 12, 2010 | 11:08 AM
terrasmak's Avatar
Then your experiance will be, i jack up the car, removed 5 lug nuts from each wheel, install my new wheels etc etc etc now i love the new look of my ride.
TrackFiddy
Sep 27, 2015 05:51 PM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
350zfreak
Sep 4, 2002 10:32 AM
nizl
Aug 4, 2002 06:14 AM
