Got the Wheels now what size tires do I get???
Old May 22, 2010 | 01:08 AM
terrasmak's Avatar
255/275 or 245/275 will give you a nice stretch, and will look good.
Old May 22, 2010 | 07:45 AM
MDHRZ's Avatar
MDHRZ
Old May 22, 2010 | 07:52 AM
lawn boy's Avatar
lawn boy
245/35 and 275/35 is pretty standard
Old May 22, 2010 | 08:33 AM
Wu-Watt's Avatar
Wu-Watt
HUH? No stretch with those sizes!!!!
Old May 22, 2010 | 09:01 AM
vex008's Avatar
vex008
Originally Posted by dkang80
I want a little stretch but nothing crazy it's a dd
well then 235/40 & 255/40 or you could try 245/35 and 265/35 to be safe and if you want more or less then sell and go the direction you prefer.
nothing wrong with proper fitment or fat tires if that's what you like, not going to knock you for it. I prefer it stretched that's all. don't understand why those that don't like it have to get their panties in a bunch all the time.
anyways good luck op
Old May 22, 2010 | 11:17 AM
terrasmak's Avatar
A 275 is stretched a bit on a 10.5 inch wheel , so is a 255 on a 9.5, its just not stupid stretch like you get with a 215 on a 9.5 and other gayness on a 10.5
Old May 22, 2010 | 11:39 AM
Romanteni's Avatar
Romanteni
10.5 rear I'd go 295 or even 305, (i got 285 on 10.0 with 38 offset, and looks hot imo).
Honestly, go 295/35/19 in rear, and 265/40/19 in front man. My imho.
Old May 22, 2010 | 01:05 PM
sbZenth's Avatar
sbZenth
Old May 22, 2010 | 01:37 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
Originally Posted by phreaktor
OMG... Don't listen to these guys. Go 255/295 and call it a day if you are already rolled.
+1 that's a nice look
Old May 22, 2010 | 01:49 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
hurry up and post piks with tires
Old May 24, 2010 | 07:47 AM
Romanteni's Avatar
Romanteni
agreed. especially if rolled, do 295s, and 255s in front, just hope you got spacers and a nice drop
Old May 24, 2010 | 11:43 AM
terrasmak's Avatar
Why would you do that, our cars already push so back and them change the tire stagger to make it worse. If you want a 295 in the back , run a minimum of 265 or prefured 275 up front.
Old May 25, 2010 | 09:46 AM
JoBAGZ's Avatar
JoBAGZ
I'm in same position 19x9.5&10.5 +14/0, but why would u run minimum of 265 or 275?
And why would u need spacers? Should be out enough already...
Old May 25, 2010 | 10:47 AM
terrasmak's Avatar
Tires change the handling, the wider the tire in the rear the more the rear traction, the wider the front tire the more front traction. It you run a 295mm wide rear tire, I would run a minimim of 265 front tire to keep the car from pushing badly in the corners. Basically the same think i mentioned about.
Spacers, probably needed if he goes for a narrow tire option. Basically anything smaller than a 275 rear and 245 front.
Old May 25, 2010 | 11:01 AM
3m wol8's Avatar
3m wol8
Originally Posted by davidv
How do you play this guessing game?
it's a hard, hard, hard game my friend
Old May 25, 2010 | 01:06 PM
Wu-Watt's Avatar
Wu-Watt
True I have 235/275 and I plowed a bit when I over shot a tight corner....
I'd still rather get a smaller tire in the rear to even that out.. Rather than a larger front. I dont track much and I like the look.
Old May 25, 2010 | 01:11 PM
ATX350's Avatar
ATX350
Originally Posted by theianmcdougall
nice, i have 18 inch vskfs in the same finish
mine are
18x9.5 +7 (225/40)
18x10 +7 (245/40
I was hoping you would chime in Ian. Definitely go with Ian's recommendation. I've seen his ride in person and its beautiful:
Old May 26, 2010 | 02:41 AM
  #38
JoBAGZ's Avatar
JoBAGZ
'preciate it terrasmak
^^^And thats a deep dish
Old May 26, 2010 | 05:57 AM
  #39
dkmesa350z's Avatar
dkmesa350z
If you want a little stretch, what is there to think about? 245/35 275/35. I would personally go with 255/35 285/35.
Old May 26, 2010 | 01:45 PM
  #40
JDM555's Avatar
JDM555
255/285 or 265/295. You're at +14, it won't be very aggressive and you won't have trouble running a little extra meat. I'd go for an aggressive meaty look if I was in your shoes. Stretch is ehh unless you're running stupid wide like 19x12 -6 lol. Just my opinion.
