Tire help
Old Jul 2, 2010 | 12:58 AM
zlatan's Avatar
zlatan
Default Tire help
So just picked up some MB battles, 18x9.5 with +15 all around...
with 25mm rear spacers= -10 offset and 20mm front spacers= -5 offset.
I'm trying to figure out what to do tire wise I figure 245.40.18's would be decent all around. Will it still feel like a staggered setup if I run my tires like this because of the spacers in terms of handling, or shall I run maybe a smaller tire in the front or wider in the rear. I understand a non-staggered setup in terms yields more neutral handling and I find myself a pretty good driver not to toot my own horn, however I figured if the contact patch stays the same so will the handling for it is still the same amount of rubber making contact with the road. Still with the camber and offset it makes you wonder. Any and all input is welcome. I appreciate all the help.
Zlatan
Old Jul 2, 2010 | 02:16 AM
BiggieB15's Avatar
BiggieB15
it depends on how low you are ..... I would go with 225/40/18 and 255/35/18 but you would need to roll your fenders...
Old Jul 2, 2010 | 03:29 AM
Nissan has a OEM 9.0 and 10.0 inch wheels. OEM tire sizes are appropriate for your needs.
Old Jul 2, 2010 | 10:38 AM
terrasmak's Avatar
Having the stagger in height also changes the way a car handles.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
