TPS...need help
Old Nov 9, 2003 | 04:04 PM
350trackz's Avatar
350trackz
Default TPS...need help
Put on iforgeds Friday and decided to wait on reinstalling the TPS for now. Problem is, the dang low pressure light comes on. Any idea how to disable it ? Fuse or something ... please help...
Old Nov 9, 2003 | 04:30 PM
ares's Avatar
ares
Veteran
nope. from what I have seen if the light was on when the TPM were removed, it keeps the last signal it had untill it learns otherwise. meaning it wont go away till you put them in and show them your tires do have air.
once you show them that you can remove them again and the light wont be on... tho some say even then it will come back after a long drive.
Old Nov 9, 2003 | 04:35 PM
350trackz's Avatar
350trackz
when i swapped the wheels out, the light WAS off It has been off since Friday. Tonight it came on after a 30 mile or so cruise.
Old Nov 10, 2003 | 02:02 PM
2003z's Avatar
2003z
It comes on after 30-40 minutes of driving, somewhere in that range. It goes out when you turn off car. Not much you can do about it, as far as I have been able to tell.
