Volk TE37 Thread
Old Feb 26, 2013 | 05:20 PM
  #941
angelo350z's Avatar
angelo350z
Originally Posted by sry110
Yes I am running extended studs front and rear, I believe 10mm longer than stock (can't quite remember). But since I eventually wanted 15mm spacers in the rear, I ended up using 15mm spacers w/ built-in studs, which are secured to my rear hubs via the extended studs. I'm lucky my wheels have the cut-outs in the back to accommodate the longer studs!
When I was running 255/35 and 285/35 I was also on +22 offset wheels, but with 5mm front and 10mm rear spacers. I had no rubbing issues, but my ride height was also higher. Never tried 10mm and 15mm spacers on that setup but I think I would have had some rubbing. It's worth trying, though....worst case you end up with one extra set of spacers.
Where is your Z? I notice in your info that you are now in Guam. Did they put your Z on the slow boat to get over to you?
Thank you, sounds good. I think I literally have every spacer size from 2.5mm all the way to 25mm with my inbound household goods shipment from storage. I'll try 10mm front and 15mm rear first, hopefull they work.
But yeah, the Z is supposed to ship from Germany by the end of March. I had to file a minor claim against the storage company for moving the car and scratching the paint. It has since been moved to the repair shop who'll make the repairs. Just waiting for the estimate and green light from the insurance company.
Old Feb 27, 2013 | 05:40 AM
  #942
sry110's Avatar
sry110
Glad to hear they are taking care of the damage. I dunno why, but I thought you were in Korea and not Germany haha
Old Feb 27, 2013 | 07:58 AM
  #943
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Old Feb 27, 2013 | 07:24 PM
  #944
gs400speed23's Avatar
gs400speed23
Mag blue not bad!
Old Feb 27, 2013 | 08:54 PM
  #945
angelo350z's Avatar
angelo350z
You're right, went to Korea for a little over a year after Germany. That's actually why I put the cars in storage.
Not sure what I like better, Mag Blue or F-Zero, both look hot.
Old Feb 27, 2013 | 08:56 PM
  #946
gs400speed23
F-zero looks better mag blue is little to dark
Old Feb 28, 2013 | 03:30 AM
  #947
AdvanZ33's Avatar
AdvanZ33
Any blue > Tiffany blue
Old Feb 28, 2013 | 09:13 AM
  #948
gs400speed23
Hahaha that's random I get that you hate tiffany blue te's
Old Mar 9, 2013 | 09:19 AM
  #949
MM'08_350Z's Avatar
How bout sum mag blue action?!?!
Old Mar 9, 2013 | 09:40 AM
  #950
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
Looks good, well done.
Old Mar 12, 2013 | 09:51 PM
  #951
doctorshumes's Avatar
doctorshumes
Default TE37 with +35 offset?
Having trouble finding what i am looking for. Trying to find TE37s in gloss or diamond black. COnsider gold as well. 18x9.5 front and 18x10.5 rear. Have found a set of bronze TE37s. The rear is ok at 18x10.5 +22 offset. But the fronts are 18X9.5 +35 offset. I know the nismo LMGT4s go up to +30 offset. Will be running a 255/40/18 front tire for now, and maybe a 265 tire later. Stoptech 6pot caliper, 355mm/14 inch rotor. SHould cover the rotor. WIll it rub on the inner fender when turning? WIll it look stupid and be too tucked in compared to the rear. Prefer not to run a spacer. Thanks for any help.
Old Mar 12, 2013 | 09:59 PM
  #952
terrasmak's Avatar
Just run a 15mm spacer and call it a day. There is nothing wrong with a quality spacer, its nothing like the spacers of 10+ years ago.
Old Mar 14, 2013 | 08:26 AM
  #953
Chebosto's Avatar
Chebosto
teh evo
from this past weekend...@ Cobb SoCal
Old Mar 14, 2013 | 08:55 AM
  #954
WillyP28's Avatar
WillyP28
So Perty
Old Mar 14, 2013 | 09:06 PM
  #955
stogey420time
Club Moderator
the Hot Spot
Old Mar 14, 2013 | 09:19 PM
  #956
angelo350z's Avatar
angelo350z
^^ Love the drop and yellow letters!
Old Mar 22, 2013 | 10:58 PM
  #957
secwind's Avatar
secwind
Old Mar 23, 2013 | 09:49 AM
  #958
ParanoidAndroid's Avatar
ParanoidAndroid
oh ****! thats sick!
Old Mar 24, 2013 | 03:39 AM
  #959
jdmlove1's Avatar
jdmlove1
^^ agree! the Akebonos look sick ! they mach the car well!
Old Mar 24, 2013 | 10:54 AM
  #960
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by secwind
Are these 18's? How is the caliper clearance with akebonos?
