tire width question 18x10 +25
Old Aug 2, 2010 | 07:45 PM
omsin523's Avatar
omsin523
Default tire width question 18x10 +25
will a 265/35/18 rub up front, i am lowered on tanabe gf210s
18x10 +25
thanks guys
i seen some pics of 265's up front when i searched but not sure of the offsets, and height the cars where dropped. And i was also in the fat/stretched tire threads.
Old Aug 2, 2010 | 08:08 PM
datsunHEAD's Avatar
datsunHEAD
you wont rub, check out the enkei thread, tons ot 265 set ups in that thread
Old Aug 2, 2010 | 11:35 PM
terrasmak's Avatar
Probably do 275/35 no problem if you want.
Old Aug 3, 2010 | 03:20 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
https://my350z.com/forum/wheels-tire...land-ohio.html
Old Aug 3, 2010 | 03:31 AM
BoomerZ33's Avatar
BoomerZ33
you should be good. what size are you aiming for in the rear?
Old Aug 3, 2010 | 03:33 AM
omsin523's Avatar
omsin523
thanks, i didnt look there
ok cool thanks
thanks, i seen this thread also so im guessing i should be fine
well, for the rear im most likely going with a 275/35/18
Old Aug 3, 2010 | 08:03 AM
Zridder19's Avatar
Zridder19
that'll fit with ease dude
Old Aug 4, 2010 | 08:12 AM
scotts300's Avatar
scotts300
You can run 265-285 up there without issue. Depending on the actual tire width, you may need a small 3mm shim-type spacer in the front. When I had 275 Hoosiers on a 17x10+25, I needed one to ensure it wouldn't rub, and it was close without the spacer. I've run 285 and 295 on the front with an 18x10 +23 wheel without issue as well.
issyz
Jul 2, 2017 03:04 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
