Varrstoen Wheels Thread
Old Jan 17, 2013 | 07:57 AM
  #1341
basata's Avatar
basata
Nobody can help?
I have now ordered xD
Rear 19x11 J15
Front 19x11 J25
I hope it fits the front
Originally Posted by basata
Hi guys.
I Need Help... i would like to buy the ES1 for my "04er Z" with the most agressiv look! I dont wont to Pull my Fenders, Rolling is ok ;-)
I Drive with apex lowering kit springs 40mm.
I think about VA 11" et12 and HA 11" et xx?
What size do you drive? Pics and experience would be very helpful!
greeting from Switzerland
Old Jan 17, 2013 | 12:31 PM
  #1342
dandiggz's Avatar
dandiggz
So I am going with the 9.5/10.5 22+ offset with 245/35/19 275/3519 nexen n7000 tires for my Z. After long research looks like this will be my best bet since im rolling on stock suspention for now. Just ordered from Concept Z Performance with blue lugs and black stems. Im guessing they will come with the center caps but not sure. Concept Z Performance has nothing but great reviews and carry alot of z oem and aftermarket stuff. Talk to Ray as he knows his sh==t when it comes to cars and can really give u some good advice. Just hope it looks decent and not out of place, if not i will be forced to drop it.
Old Jan 17, 2013 | 02:34 PM
  #1343
CannMann21's Avatar
CannMann21
Originally Posted by phased1
Okay so 10mm more inward wouldn't that make it look a bit more flush?
How many psi should I pump up the wheels?
Also in the future if I get the 18x9.5 front and 18x10.5 rear with a +22 offset set up will I still be able to lower if I wanted to?
I am not too sure, maybe 35 psi? Mine are over inflated because of winter storage.
Just go with +22 offset. If you decide to lower, you will be fine.
Originally Posted by Donati06Z
hay thats my car!
Post your specs, maybe you can help phased.
Old Jan 17, 2013 | 04:38 PM
  #1344
rippn's Avatar
rippn
Default Wheel/Tire size options, Varrstoen 2.2.2 or Sportline TE.6?
Hey all,
After reading most of the posts in this thread and a few other threads I have a good idea of what I want but I thought I would post what I am thinking so I can get some feedback and make sure I'm not forgetting something. I want as wide as I can go in the rear, I know I will need to roll the rear fenders, if I need to pull I can do that too, but I would rather not pull uf I can help it. I have an 03 z, 6 speed touring, 18" stock wheels (previous owner chromed them and on my black z I don't like the look), non-brembo (I will eventually get big brakes), Tokico coilovers, lowered an inch as it sits now.
Tokico coilovers - I don't know much about them, they were on the z when I bought it. From my measuring it appears that it is lowered one inch. I would like to get it lower but I don't think I can lower it with these coilovers without getting shorter springs, is that right? What would I need to do to get it lower another inch or two?
Wheel size - I am thinking front 19x9.5 +12 , rear 19x11 +15. I would need a spacer for the rear to get to +15 right? I saw some setups in this thread that I liked with those specs. I don't want a lot of stretch and I want it really wide in the rear... there are some sick jokes in there somewhere...
Tire size - Front 265/35, Rear 305/35. I don't want a lot of stretch. I have read about the 3% rule to keep VDC and ABS happy and I have seen posts that say the increase in tire size shouldn't be more than a difference of 3% of the stock OD size and the new tire OD size and posts that say the increase in size shouldn't be more that a 3% diff between front and rear OD sizes. If its the first, the fronts 265 (26.3 in OD) and the stock 225 (25.97 in OD) are a diff of 1.3% and the rears 305 (27.4 in OD) and the stock 245 (26.68 in OD) are a diff of 2.6% so that would work. If its the later, the % diff between the front 265 (26.3 in OD) and the rear 305 (27.4 in OD) is 4% so that wont work... which one is it?
Varrstoen ES222 or Sportline TE.6 - I don't have the cash for new Volk TE37s, so as far as I can tell these are the best options? They are close to the same price as far as I know, anyone have any input on which way to go?
Sorry for the huge post, after reading through this thread I got a bunch of stuff rolling through my head and wanted to get it down for peoples input and opinions... Thx!
Old Jan 19, 2013 | 12:30 PM
  #1345
phased1's Avatar
phased1
Question if I get 245/40/18 front and 275/40/18 rear tires for 18x9.5 front and 18x10.5 rear with a +22 offset. Will I have to go to a shop for them to put them tires on the rims since it's a small stretch?
Old Jan 22, 2013 | 02:02 PM
  #1346
ModBargains's Avatar
ModBargains
Vendor - Former Vendor
Originally Posted by rippn
Hey all,
Go with Sportline TE.6, they are high quality rotary forged production wheels. They also weight less than Varrstoen ES222 , also comes with a durable Matt Black powder coated finish with a protective clear coat.
Old Jan 23, 2013 | 12:08 PM
  #1347
stevo_ef91's Avatar
stevo_ef91
got a little issue was hoping someone on here could help.
traded for these wheels and they came with tires.
varrstoen 1.1.2
19x9.5 +22 235/35/19
19x11 +25 275/30/19
had some tire issues on the front tires and had to take whatever the tire shop had in stock.
so i had to put on 255/35/19 up front.. i really like how flush they are with wheel. im trying to get away from the stretched tires that were on their previously.
so my question is what size tire do you recommend replacing for the rear. i dont want any stretch but dont want a massive side wall..
been looking at 285/35/19 or 305/30/19
i would like the fattest tire without that bulge look. im only worried that the 305/30's will look too skinny.
extra info: stock ride height for now. I will be getting coilovers in the next couple months. i plan lower the car to have just a little bit of gap over the tires. and rolling fenders is ok ive done it before and plan to do it to this car.
any help would be much appreciated thanks!
Old Jan 24, 2013 | 07:44 AM
  #1348
rippn's Avatar
rippn
I like the TE.6, if they came in offset +12 and in a 19x11 I would have them ordered. I wanted +12 all around and 19x11 in the rear, so I'm still thinking.
Old Jan 25, 2013 | 11:38 AM
  #1349
VarrsToen's Avatar
VarrsToen
VARRSTOEN GIVEAWAY ---> http://www.varrstoen.com/photocontest/
Old Jan 28, 2013 | 08:11 PM
  #1350
z33jdm's Avatar
z33jdm
ES 552
19x9.5 +12
19x10.5 +12
245/35R19 All around
Old Jan 28, 2013 | 09:56 PM
  #1351
Esser's Avatar
Esser
^^wow, looks awesome. Dont see too many of the 552's on Z's
Old Jan 30, 2013 | 06:28 AM
  #1352
dandiggz's Avatar
dandiggz
Finally got my Varrs on. Lookn sweet. 19s 9.5/10.5 +22 245/35 275/35
Old Jan 30, 2013 | 07:21 PM
  #1353
solidsnake's Avatar
solidsnake
^ moar plz of the 552 setup. +12 looks flush
Old Jan 30, 2013 | 09:16 PM
  #1354
vex008's Avatar
vex008
looks really good z33jdm. more pics are a must
Old Feb 1, 2013 | 02:09 PM
  #1355
locoblade's Avatar
locoblade
Default Wat are the Specs on the ES 5.5.2
What are the Specs on the ES 5.5.2 on the 370z
And How Aggressive fitment can I get with as Z with brembos and Pulled fenders 15mm
Originally Posted by VarrsToen
Finally mounted on a Z (ES 5.5.2)
Old Feb 1, 2013 | 02:48 PM
  #1356
VarrsToen's Avatar
VarrsToen
Giveaway Contest has OFFICIALLY started: www.varrstoen.com/photocontest
1) Visit our fanpage: www.facebook.com/varrstoenwheelsUSA
2) Like the page
3) Click on "Photo Contest"
4) Read all Rules and Regulations before submitting a photo
You are only allowed to submit a phone ONCE! It will not allow multiple submissions so it better be your best one! Photo MUST follow the announced theme of "Show us how much you love your car".
Example:
Old Feb 4, 2013 | 03:06 AM
  #1357
323_z33's Avatar
323_z33
Smile Wowww
Green Varrstoen 18x9.5 +13 f 18x10.5 +15 r on silver z Takata green es222 what size tires should be good my z has that vdc I heard about slip problems when wrong tires are installed
Old Feb 4, 2013 | 05:48 AM
  #1358
NoQuestionZ's Avatar
NoQuestionZ
255/35/18 Front 285/35/18 Rear.
/thread
Old Feb 4, 2013 | 06:20 AM
  #1359
j3tt2's Avatar
j3tt2
Sexy as f*ck
Old Feb 4, 2013 | 06:52 AM
  #1360
323_z33's Avatar
323_z33
These are my option 100% I just need 100 more to get these green from Varrstoen coming up soon
