VarrsToen|ES 1.1.2 Deep Polished Lip 19"
VarrsToen told me yes with those tire sizes but S&R Performance in Tampa said I would not need to roll. I guess we will see when my wheels get here in a couple days.
The rivets are removable. They pop in and out.
Glad we were able to help you out man. Appreciate the great communication and cant wait to see it installed.
We did a local test fit on a G35/350z with Brembos. To clear the front brakes, you will have to use the +12s and run a 3mm spacer which will bring it to a +9 offset. +0s will clear with no issues since its a larger backpad. Machining will not do anything except raise the offset. Raising the offset means that the backpad will be smaller therefore reducing the amount of clearance.
just wanted to tell you that you had the wheels on my car listed as +22, they are +12 with 245/35 and 275/35 tires on them, theres also a couple more pics of them installed with tires back on page 5
I know what you mean, the BBS caps just look too good to pass up compared to a solid cap, but unfortunately the real ones don't fit since they're 70mm wide. You need 68mm replica ones with a 62mm base for Varrstoen and I was lucky enough to pick some up a good while back before the vendor stopped selling them (apparently BBS doesn't like it very much when you sell knock off caps). I also have a set of 65 mm BBS rep caps which have a tiny gap when mounted into the varrstoens. They fit and hold snug just the same since the base is 62 mm, but the actual top cap part has a 1.5mm gap. Ill be selling them shortly and have some pics so pm me if you're interested.
Vendor - Former Vendor
All PMs sent and Replied! Guys these are selling out fast!!!! For those who posted teaser pics... they're looking good!!! Can't wait to see finished pics!
Hmm... that would be a pad idea. If you're going to do any shaving, would rather shave the caliper (although it'll remove the finish and "brembo" logo) versus shaving a bunch of spokes.
Mine arrived today and look really good. Hopefully motor and turbo will be back in the car by the end of next week and will post some pics then. Thanks for the tracking and all the follow ups Phi you guys are great.
