Tire Sensor question..
Old Feb 1, 2011 | 07:02 PM
SilverCarbon's Avatar
SilverCarbon
Default Tire Sensor question..
My 350z doesn't have sensors but i'm getting rims that have them. Can you take them off the stock and put them on the mrr rims? how does this work? does it go in the tire? in the rim?
Old Feb 1, 2011 | 09:41 PM
sdZ33's Avatar
sdZ33
They go on the wheels just like regular valve stems... Instead of pulling them through like the rubber ones, you screw them on... Any tire shop can do it... Now it depends on the wheels if they accept tpms... If not, then you need the tpms adapters... GL
Old Feb 1, 2011 | 09:44 PM
SilverCarbon
Thanks! what if I don't have TPMS but my wheels do not going to do anything right?
Old Feb 1, 2011 | 09:48 PM
350ZTheStandard's Avatar
350ZTheStandard
Fact, the car has to have the ability to read the TPS sensors, they are located in the passengers side front pillar I believe. Check your owners manual.
good ruck fella
Old Feb 1, 2011 | 09:51 PM
sdZ33's Avatar
sdZ33
If you don't have tpms on the wheels and you put them on the car, it just won't tell you the tire pressure, and after 50 miles or so of straight driving, the light on the dash will turn on... It will go away when you turn off the car, but it will do it again if you drive the same distance non-stop...
In other words, you'll be fine
Old Feb 1, 2011 | 10:02 PM
SilverCarbon
What about if my car doesn't have TMPS but my tires do?
Old Feb 1, 2011 | 11:29 PM
sdZ33's Avatar
sdZ33
TPMS is the sensor, it replaces the valve stems on the wheels... Your tires don't have them the wheels do... If your wheels don't have the sensors(TPMS), then you can't read the tire pressure on the cute little info center-thingy on the pods...
Old Feb 2, 2011 | 03:33 AM
Yes. Mark the sending units front passenger - front driver. Put them in the same wheels.
Old Feb 2, 2011 | 03:35 AM
There is no system to read the signal from the sending units.
Old Feb 2, 2011 | 03:37 AM
huyrua's Avatar
huyrua
The you will void your warranty forever.
Old Feb 2, 2011 | 07:44 AM
SilverCarbon
LOL Thanks guys. I was just wondering cause I've never seen a tire light on my car even after I took the stocks off and replaced them with the MRR's I was wondering if it could have the system and with the new stocks i got that have TMPS if I could activate the system and if it does how can I tell if it does? I have a touring edition
Old Feb 2, 2011 | 02:44 PM
Look at the owners manual. You may able to click through the computer and find tire pressure.
Old Feb 2, 2011 | 02:56 PM
SilverCarbon
Thanks made the swap and everything is good.
Old Feb 2, 2011 | 02:59 PM
Thumbs up
ablaine
Nov 29, 2016 10:13 AM
