ADR M-Sport Wheels
Old Dec 1, 2003 | 05:56 PM
Spartan1510's Avatar
Spartan1510
Any issues with the track Brembos? Do they require spacers?
Old Dec 1, 2003 | 06:28 PM
N74DV's Avatar
N74DV
I've heard that they do require spacers but I'm not 100% sure about that
Old Dec 1, 2003 | 07:52 PM
neur0sis's Avatar
neur0sis
Originally posted by Conceyted
Well, I have one question. The wheel gap with the stock 17" setup is near NONE. With this setup your gap seems to have increased. Is this the case, or should I go back outside and have another look at my 17's?
Well, seeing as the tire sizes I chose gave me almost EXACTLY the same diameter as my stock 17"s, I'd say go back outside and check.
I took these pics with the camera on the ground, pointing UP at the Z, so it probabally has to do with the angle. That, and since it was sunset, the shadows may play a few tricks as well.
The only other thing I can think of, is that the springs might have needed a little settling after jacking the car up to put the wheels on... it looks normal to me now.
Old Dec 1, 2003 | 08:15 PM
Conceyted's Avatar
Conceyted
Did the traction rods/bars by lsd reduce or eliminate your wheelhop. It is my worst enemy at the current moment.
Old Dec 1, 2003 | 08:27 PM
Moroccan_Mole's Avatar
Moroccan_Mole
you WILL have to use spacers with the stock brembos... i tried to fit my wheels onto a g35c with brembos and it wasn't close to fitting.
Old Dec 2, 2003 | 07:08 AM
kbomb's Avatar
kbomb
I have the same setup as Neurosis...Im not sure if there is a bigger gap than the stock 17s...
check it out..and lemme know
http://www.cardomain.com/memberpage/420722
Old Dec 2, 2003 | 02:11 PM
ADMAN's Avatar
ADMAN
ADMAN
Old Dec 11, 2003 | 04:02 AM
Gweedo's Avatar
Gweedo
I've had mine for about 8 months now. I believe I was one of the first to put them on a Z.
I LOVE them. I have them in 19x8.5 and 19x9.5 with 245's and 285's.
They are about the same weight as my stock 17's. They are lighter than you'd think for a cast wheel.
I've hit some nasty pot holes and have never bent a rim.
The one thing I did have to do was run spacers because the offset was a little too large for me..... but spacers are not needed.
Your car looks ****! I think these are going to be the wheels I buy. What offset did you get and why exactly are you running spacers? Did they sit too far into the wheel well? What offsets do they offer?
Thanks
Old Dec 11, 2003 | 04:30 AM
Conceyted's Avatar
Conceyted
Originally posted by ADMAN
ADMAN
18s or 19s?
Old Dec 11, 2003 | 06:02 AM
N74DV's Avatar
N74DV
I think they only offer +35mm in the 19's. That offset is fine. It puts the wheels right about where the stock ones would be.
I prefer a more aggressive wide track where the wheels are just barely clearing the fender.... hence the spacers.
Old Dec 11, 2003 | 08:06 AM
mf01's Avatar
mf01
N74DV,
Where did you get the Falken tires and how much do they run? I'm think about getting the 19" ADR's.
Old Dec 11, 2003 | 08:12 AM
N74DV's Avatar
N74DV
I got thetires from Discount Tire. $1,050 mounted & balanced
Old Dec 11, 2003 | 08:24 AM
mf01's Avatar
mf01
How many miles do you think you'll get out of them? One other thing, are they feathering at all? My stock tires are feathering like no other. I might just wait till Nissan or I fix the suspension.
Old Dec 11, 2003 | 11:10 AM
TriX's Avatar
TriX
ADMAN you have ADRs?
slay2k i think i asked you before is your car lowered?
Old Dec 11, 2003 | 01:58 PM
N74DV's Avatar
N74DV
I expect to get about 10,000 miles out of them. I drive fairly aggressive. They are not feathering... but I am lowered about 1.8" so that may change things.
Old Dec 11, 2003 | 02:01 PM
grapela's Avatar
grapela
neurosis,
I want to go with the exact setup you have in 18's what is the exact specs of your wheel18x what , what is the offset, and what size tires are you using. thanks
Old Dec 11, 2003 | 02:58 PM
neur0sis's Avatar
neur0sis
My specs are:
18" x 8.5" front +35 offset
18" x 9.5" rear +35 offset
Tires are Kumho Ecsta MX
245/40/18 front
275/40/18 rear
Old Dec 11, 2003 | 04:07 PM
  #38
Bertg's Avatar
Bertg
Originally posted by neur0sis
My specs are:
245/40/18 front
275/40/18 rear
That's the same size I plan on using. I may go with Nitto or Goodyear tires. Are you experiencing any tire feathering/cupping problems with your setup? Did you have your alignment checked after putting in the wheels and tires?
Thanks!
Old Dec 11, 2003 | 06:05 PM
  #39
Bertg's Avatar
Bertg
My specs are:
245/40/18 front
275/40/18 rear
Thanks!
Old Dec 11, 2003 | 06:23 PM
  #40
neur0sis's Avatar
neur0sis
Thanks!
They have been on for a few thousand miles, and no feathering yet. I didn't really have any problem before either, though. I am going for an alignment after I get my suspension put on (B+G Springs with LSDUnique rear camber arms)
