TPMS Problem?
Old Mar 30, 2011 | 11:26 AM
AadosX's Avatar
AadosX
Default TPMS Problem?
I just got my TPMS sensors back from a tire shop that removed them from a set of wheels and the little pins that are inside the valve stem part are missing. So it's just like a hollow tube going into the electronic box part. I hope that makes sense.
What gives? Can I fix this somehow? I have heard of TPMS rebuild kits but I'm not sure if that's what I need or what.. I can't find much info on the subject.
Thanks,
John
Old Mar 30, 2011 | 11:43 AM
AadosX's Avatar
AadosX
Ok I'm not sure but I think I've answered my own question. It looks like a lot of the rebuild kits come with a new schrader valve. I'm not sure how that works... but hopefully it will fix my issue.
Old Mar 30, 2011 | 11:52 AM
AadosX's Avatar
AadosX
Here is a link:
http://www.schrader-bridgeport.com/f...MS_catalog.pdf
Part number 20014 for 2007+ 350Zs
Hopefully this will help someone else in the future!
Old Mar 30, 2011 | 12:47 PM
terrasmak's Avatar
The schrader valve just screwes in, some valve caps are even made with the tool to do it on them.
Old Mar 30, 2011 | 01:11 PM
Voboy's Avatar
Voboy
When you put the tpms's on your new wheels or whoever does, and when they get the tire mounted and beaded, the final step is to insert that screw in for the air to stay in the tire... these are abundant at any tire shop and usually included in the price it costs to mount a tire. TPMS or not... this is how valve stems work.
edit: i'm not 100% sure which pin your talking about.
Old Mar 30, 2011 | 01:22 PM
DavesZ#3's Avatar
DavesZ#3
You talking about one of these?
There's nothing special about them, you can pick one up just about anywhere tires or auto supplies are found.
Old Mar 30, 2011 | 02:02 PM
redman333's Avatar
redman333
You just need the inner valve. Most tire shops take them out to let the air out of the tires and then put them back in when they finish. Are you installing them or is a tire shop going to be putting them on, if so then they will put the valves in for you.
Old Mar 30, 2011 | 02:22 PM
AadosX's Avatar
AadosX
Ok guys. Thanks for the info. Yeah I have always watched tire guys do their thing and I've seen them unscrew something to let the air out.. but I never knew what they were doing exactly. So I guess this shop was just ghetto and didn't bother putting them back in? lol.. sigh..
Well, since this will now be my 3rd time to uninstall then re-install these TPMS I think I might go ahead and get the rebuild kits with new rubber grommets so that they don't leak any air.
Old Mar 30, 2011 | 04:41 PM
zerostyle's Avatar
zerostyle
if you need rebuild kits lmk and i can get em for you cheaper than anywhere else....and ill send you a tool to svrew the valve core (what holds air) in and out
Old Mar 30, 2011 | 04:46 PM
surfcity40's Avatar
surfcity40
Man, it's been a while since I explained the difference between direct and indirect systems. I'd have to link from somewhere else.
Old Mar 30, 2011 | 05:05 PM
zerostyle's Avatar
zerostyle
OP all you need is valve cores...you dont NEED rebuild kits, but if you want em hit me up...if a tire shop tries to charge you for valve cores thats messed up...
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
