Wheels & Tires Wheels, Tires, Big Brakes, Coilovers, etc...
Z1 Hub Centric Wheel Spacers & Extended Studs
Old Mar 31, 2011 | 01:55 PM
Z1Motorsports's Avatar
Z1Motorsports
Default Z1 Hub Centric Wheel Spacers & Extended Studs
Our Hub Centric Wheel Spacers with Extended Studs are CNC Machined from Billet Aluminum and are perfect for achieving that flush look. Available in 5mm, 10mm, 15mm, or 20mm, these spacers should suit any of your wheel spacing needs. If you require something in between the spacer sizes here, we also sell 2.5mm Hub Centric Wheel Spacers which can be used in conjunction with these spacers and extended studs.
Our 5mm Hub Centric Wheel Spacers remain flat to allow the hub center to protrude for centering of Hub Centric wheels whereas our 10mm, 15mm, and 20mm Hub Centric Wheel Spacers all have an extended hub portion to allow for centering of Hub Centric wheels.
Kit includes:
(2) Hub Centric Aluminum Wheel Spacers (Your Choice of 5mm, 10mm, 15mm, or 20mm)
(10) Extended Wheel Studs (10mm longer than stock for 5mm and 10mm spacers, 20mm longer than stock for 15mm or 20mm spacers)
*ARP Studs are offered as an option*
This kit can be found Here.
We also offer Bolt-on style Wheel Spacers. These bolt-On Wheel Spacers are CNC Machined from Billet Aluminum and are perfect for achieving that flush look. Available in 20mm, 25mm, or 30mm, these spacers should suit any of your extreme wheel spacing needs.
Our Bolt-On Hub Centric Wheel Spacers all have an extended hub portion to allow for centering of Hub Centric wheels.
Whats Included:
(2) Aluminum Hub Centric Wheel Spacers with Studs Installed (Your Choice of 20mm, 25mm, or 30mm)
(10) Nuts to attach spacers to existing studs on vehicle
More info can be found HERE
New stud options available.
Old Apr 2, 2011 | 10:29 AM
Z1Motorsports
These kits will fit with any big brake kit.
Old Apr 2, 2011 | 11:00 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I'm thinking I need spacers fir my rears. However I'm extremely paranoid about adding spacers bc of horror stories iv heard. I'm a noob to b honest. I have a 295/35/18 10" wheels with 30 offset. I'm thinking a 20mm spacer will poke my wheels out to my proper stance. Any info will b appreciated. Thx
Old Apr 2, 2011 | 12:42 PM
Z1Motorsports
When adding spacers, the biggest concern is making sure there is enough stud length for the lug nut. With a 20 mm spacer we highly recommend using our extended studs to ensure proper bolt length retention.
A 20mm offset should give the wheels a flush look on you car.
Old Apr 2, 2011 | 01:13 PM
2004Black350z
Exhaust Whore
Ok how much for 2 20mm spacers with extended studs shipped to 27253
Old Apr 2, 2011 | 01:49 PM
Z1Motorsports
You can click the link above which takes you to our website, select the 20MM spacers and add to your cart. At check out before taking payment info it will give you the cost for shipping and overall total.
Old Apr 6, 2011 | 02:41 PM
Z1Motorsports
We also sell Extended Lug Bolts separately from the wheel spacers.
Old Apr 14, 2011 | 06:54 PM
Z1Motorsports
All sizes in stock, ready to ship.
Old May 1, 2011 | 04:11 PM
Z1Motorsports
Pick up a set today to achieve the flush look on your Z.
Old May 4, 2011 | 09:36 PM
Chebosto's Avatar
Chebosto
do you have other bore sizes or are these only for Nissan?
Old May 20, 2011 | 11:22 AM
bonarsauce's Avatar
bonarsauce
Just got 2 sets of these in 20mm in today and they look great, thanks!
Old May 23, 2011 | 06:29 PM
motomadness910's Avatar
motomadness910
plz pm me best price for built in screws and regular 25mm front 30mm rear
Old Jun 2, 2011 | 10:31 AM
Z1Motorsports
Pick up your set today!
Old Jun 7, 2011 | 06:26 AM
Z1Motorsports
Add any 5mm to our 10mm or 20mm spacer for a little extra flush look.
Old Jun 15, 2011 | 07:02 AM
driver1712's Avatar
driver1712
i thought it's not recommended to add a spacer on top of another one
Old Jun 15, 2011 | 07:13 PM
Z1Motorsports
There's no issue with using multiple spacers as long as the studs are of sufficient length.
Old Jun 19, 2011 | 08:22 PM
Z1Motorsports
Plenty of kits in stock, ready to ship.
Old Jun 27, 2011 | 08:30 AM
Z1Motorsports
The flush look is only a spacer away!
Old Jul 2, 2011 | 11:04 AM
drivessidewayz's Avatar
drivessidewayz
Do you guys sell/have in stock ARP studs as well? If so, can you price two 10s with ARP studs for both? I would try looking it up, but your website doesn't seem to be fully operational.
Old Jul 7, 2011 | 09:13 AM
Z1Motorsports
We do not carry ARP studs. We only carry Nismo and Z1 brand studs.
