Wheel size question
Old May 1, 2011 | 09:20 AM
jonathuggg's Avatar
jonathuggg
Default Wheel size question
Currently I have the stock Touring V.2 Wheels on my car. The specs on that are
Front
Offset: +30mm
Weight: 24.4
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 25.8
Tire: 245/45/18
I am looking into buying 18x9.5 ROTA P45R Wheels. The specs on those are
Bolt Pattern: 5x114.3mm
Offset: 30 mm
I wanted to know will that fit since all the tires are the same size and right now I have staggered wheels since my rear wheels are wider? Also does it matter that all 4 wheels are P45R which are the rear wheels and they have more concave? And since they are 30mm offset I dont need any spacers for the front or rear do I? I am sorry if these are dumb questions, I am a noob when it comes to cars and I just got mine like 4 months ago.Thank guys!
Old May 1, 2011 | 09:30 AM
angelo350z's Avatar
angelo350z
The Rota P45Rs are Nismo LMGT4 replicas so yes, running a square setup (18x9.5 +30 all around) will work just fine. I suggest NOT using your OEM tires as they are vey narrow (225/245) for the wider Rotas. Spacers won't be necessary, but getting a set of 10mm would definitely make your car look better.
Old May 1, 2011 | 09:33 AM
jonathuggg's Avatar
jonathuggg
Thanks a lot Angelo!
Old May 1, 2011 | 10:05 AM
angelo350z's Avatar
angelo350z
np, check out this thread for reference:
https://my350z.com/forum/wheels-and-...ls-thread.html
Old May 1, 2011 | 11:33 AM
terrasmak's Avatar
Don't they offer a 9.5 in +20 , i would get them front and rear then add a 10mm spacer to the back.
Old May 1, 2011 | 11:55 AM
angelo350z's Avatar
angelo350z
^^ That would look good, just be ready to roll your fenders.
Old May 1, 2011 | 12:57 PM
Compare the current wheel to the new wheel.
Do you have 19 mm between the tire and strut to spare?
Do you have 19 mm between the brake calliper and wheel to spare?
DarkCreep
Oct 17, 2015 11:50 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
