FIC Brand Spacers
Old May 3, 2011 | 09:57 AM
350zspl's Avatar
350zspl
Default FIC Brand Spacers
anyone try this brand
FIC Wheel Spacers
hub centric
with studs pressed in
with all fasteners
the come in 10mm, 15mm, 20mm, 25mm
anyone ?
Old May 3, 2011 | 11:16 AM
350zspl's Avatar
350zspl
i guess i will let you know how they are
i just ordered 1 pair in 10mm, hub centric , with studs pressed in
they stock them at SSR in California
what i liked about them other than very high end look and build quality is that they are the only people i have seen that do a 10mm with studs pressed in
Old May 3, 2011 | 02:17 PM
terrasmak's Avatar
I would never run a spacer with studs pressed in under 25mm, then again i also would never run a 25mm spacer.
10mm spacer with studs pressed in , the studs will be pressed into less than 5mm of aluminum, most cars have steel hubs, steel is stronger, do i want all the force of my car riding on thin aluminum? NO
Old Jun 20, 2011 | 09:17 AM
TheDangerZone's Avatar
TheDangerZone
I called morejapan and found out that for the 10mm, you need pockets in your wheels so that the nuts for the spacers will clear. anyone try these yet? Evasive has them for a pretty good price.
aboodi
Oct 28, 2015 02:07 PM
