Wheel fitting question, 19" Varrstoen 2.2.1
Old May 28, 2011 | 12:14 PM
Jerodmark's Avatar
Jerodmark
Default Wheel fitting question, 19" Varrstoen 2.2.1
Hello I found a set of 19" Varrstoen 2.2.1 wheels with tires on craigslist and wondering if the offsets will work with my 06 Z. Lug pattern: 5x114.3
Front: 19x8.5 +32 ???
Rear: 19x9.5 +35 ???
Thanks
Old May 28, 2011 | 03:08 PM
STL 350Z's Avatar
STL 350Z
Those offset's are horrid... they will set to far inward. I suggest save your money and buy from a vendor here with the correct offsets for the Z.
Old May 28, 2011 | 05:31 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
_koubie_
Sep 20, 2015 06:34 PM
