Help with tire size
Im in the market for some new wheels and this wheel is one of the ones I am considering. My question is, is anyone running these wheels? If so what tire size are you running or should I run. The wheels are 19x9 front and 19x10.5 rear. I cant find any info on what the offset is. Any advise would be greatly appreciated.
I have a 2006 DB Base Model. I dont believe i have VDC. So I found out that the offset for these are 20 for the 19x9 and 25 offset for the 19x10.5. I will be lowering the vehicle on tanabe nf210.
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
For wheel-tire width see: http://www.tiresandco.ca/equivalency-tables-advice.html
