NEED HELP with Volk SF Challenge
Old Jun 3, 2011 | 02:10 AM
BulletMagnet's Avatar
BulletMagnet
Default NEED HELP with Volk SF Challenge
Hi guys, I am in need of some help here.
I have sent my Volks to be refurbished and all is well so far, apart from when they split the centres from the dishes, they forgot to mark up which were the fronts and which were the rears.
Now the offsets are +28 for the front and +23 for the rear, but the guy tells me that it's not stamped on the inside of the centres.
Can somebody help me on this, perhaps post pics if they have the same wheel size Volks?
Fronts are 19"x9.5J offset +28
Rears are 19"x10.5J offset +23
Thanks for any help, it's appreciated.
Old Jun 3, 2011 | 02:44 PM
Not certain why swapping centres of 2 piece wheel would alter offset. Offset is determined by placement of center on the barrel. The location is fixed.
You have 4 wheels and the centres are different shapes?
How about you post photos about what you are talking about.
Old Jun 3, 2011 | 04:48 PM
stinky350z's Avatar
stinky350z
all 4 faces are the same size bro ,nothing will happen if u put the rear wheel face on a front wheel face,
good luck
Old Jun 4, 2011 | 12:37 AM
BulletMagnet
Thanks for the replies guys.
Since then, I have figured out that the wheelnuts sit in deeper on the front wheels than the rear.
This would account for the larger offset on the front of +28 compared to the lower offset on the rear of +23, because the wheelnuts are all the same size.
Front
Rear
Old Jun 4, 2011 | 01:39 AM
VQpoweredZ's Avatar
VQpoweredZ
Thats just what I was going to suggest you try and do. Your 100% right because my Neo Chro extended lugs sit almost inside the front disks, and poke in the rear disks. Glad you got everything figured out.
