help with traction control
Old Jun 13, 2011 | 07:34 PM
skoke70's Avatar
skoke70
Default help with traction control
Need help! I just bought a 04 roadster and when I take a corner at a decent speed the traction control kicks in.
The guy I bought it from had 245/45/17 on the front and 225/50/17 in the rear. After doing some research on this forum I found out it was because the different tire sizes causing the traction control to come on during cornering.
To try and solve this problem I put a set of 245/45/17 in the rear to match the fronts and stop the TC from engaging when cornering.
I took the car out for a drive after the new tires were installed and the TC in still coming on when I take a corner with any bit of speed! Why? Can anyone give me some advice on how to fix this? Thanks
Old Jun 13, 2011 | 09:09 PM
Do you have VDC?
Old Jun 14, 2011 | 05:16 AM
skoke70's Avatar
skoke70
I don't know?, I do have the button to turn off the traction control. where do I check to see if I have VDC? My roadster is the grand touring model if that helps?
Old Jun 14, 2011 | 05:53 AM
VDC and TCS are the same button. If is says TCS you do NOT have VDC.
The 4-square set-up should NOT be a problem with TCS. I assume you are running:
F-17x7.5
R-17x8
Inspect the wheels with a tape. Make sure you are running the same size wheels on the rear axle.
Old Jun 14, 2011 | 07:09 AM
terrasmak's Avatar
Grand touring will have VDC, no go read the top 100 question. It will tell you what is wrong with your car.
Old Jun 14, 2011 | 09:13 AM
DavesZ#3's Avatar
DavesZ#3
https://my350z.com/forum/showthread....1&postcount=45
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
