Rim offset help needed please
Old Jul 27, 2011 | 07:38 PM
savedbygrace's Avatar
savedbygrace
Default Rim offset help needed please
Hi guys,
I have an '04 Z Coupe Base model, and want to put on some new rims and am struggling to understand all aspects of the offset...
Bottom line is this:
I have some 3rd party front rims with an offset of +15 and rear rims with an offset of +43.
Stock offsets on a Z I believe, (for stock 18" rims) is fronts of +30 and rears of +30.
Stock offsets of 17's on a Z I believe are fronts at +30 and rears at +33. (and they're tucked into wheel well a little bit)
If my 18's are NOT STOCK, can I use the stock 18" stock rims specs to gauge how well my own 18" rims will fit? I'm doing this like so: I compare my 3rd party rims offset of +15 for front to the 18" stock offset of +30 and am thinking that means my 3rd party rims will stick OUT 15mm more than the stock look? Will this be ok? Will it just get flush to car or will it stick out too much?
Then I compare the rear offsets, with the 3rd party rims at +43 and the stock 18" rims are +30, which means they'll tuck IN 13mm more than stock? Therefore I need 15mm or 20mm spacers to make them look right?
Am I onto this correctly, or have I left something out?
Mind if I bug you Z veterans if there is any problem with this scenario?
Thanks so much everyone, once I have the answer to this I can put the rims on, assuming this will work out ok.
SavedbyGrace
Old Jul 27, 2011 | 07:41 PM
lgear080's Avatar
lgear080
why would you ever put a +43 rear offset rim on a z for any reason?
just put stock rims on and save your loot.
dump the wheels you have.
Old Jul 27, 2011 | 07:44 PM
SuperBlack350z's Avatar
SuperBlack350z
+ 1 million.
Old Jul 27, 2011 | 08:21 PM
Waiz's Avatar
Waiz
Please read this thread before creating another one in this section:
https://my350z.com/forum/2003-2009-n...questions.html
https://my350z.com/forum/2487452-post8.html
4 threads on wheels is unnecessary and creates clutter.
ablaine
Nov 29, 2016 10:13 AM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
