19x12 with a 3.5 inch lip
Old Aug 3, 2011 | 11:48 AM
gzelda's Avatar
gzelda
Default 19x12 with a 3.5 inch lip
has anyone tried to fit a 19x12 with a 3.5inch lip on their Z? and I dont have a wide body kit on my car. Sorry not sure what the offset is as of right now. thank for the help.
So i was told this needs more info (sorry i made assumption) true coil over (stance) adjustable camber kit,& adjustable toe kit, and fenders are rolled. Car has been dropped about 2inch as right now, but i dont mind raising it if i can fit 19x12. I dont care what tire size i have to run and i will try to get the offset of the rims soon. Just wanted to know if any one has been able to fit 19x12 on the rear so i can start looking more into this. thank you
Old Aug 3, 2011 | 12:00 PM
gvulakh's Avatar
gvulakh
Your question needs more info. Definitely need to know offset of the wheels. Are you lowered? How low? Do you have adjustable camber arms? What size tires? Are your fenders rolled/pulled? Probably missing stuff too. I'm no expert.
Old Aug 3, 2011 | 01:20 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Without knowing the offset it's impossible to tell. I'm making a guess here, but I'd say yes they'll fit but you'll need some fender mods.
Here's a Z with really aggressive fitment:
20x9.5 -5mm and 20x11 -5mm
Old Aug 3, 2011 | 01:38 PM
Its never been done before. Call yourself a pioneer. A my350Z.com trailblazer.
Old Aug 3, 2011 | 01:45 PM
Vivid Racing
Vivid Racing
A forum member named ryanmac516 might disagree
Old Aug 3, 2011 | 02:23 PM
03BrickZ's Avatar
03BrickZ
https://my350z.com/forum/nolazcc/422...-big-pics.html i completely agree
Old Aug 3, 2011 | 02:38 PM
JCITY's Avatar
JCITY
Too big...the pic(blue z)over the top...tires diameter/tread too small.
I'm sorry,these kinda setups are not what the Z was designed for.
Old Aug 3, 2011 | 04:23 PM
driver1712's Avatar
driver1712
i hinted sarcasm from davidv
Old Aug 3, 2011 | 05:53 PM
datsunHEAD's Avatar
datsunHEAD
19x12 with only a 3.5 lip?sounds like a highoffset rim just do it like nike son!!
Old Aug 3, 2011 | 06:18 PM
CORNELL's Avatar
CORNELL
19x12 -12 offset almost 6" lip... do work son!
Old Aug 3, 2011 | 06:27 PM
AmateuRN's Avatar
AmateuRN
19x19? Jesus. Tires custom made like Shaq's shoes?
Old Aug 3, 2011 | 07:10 PM
Waiz's Avatar
Waiz
+1
Without an offset for the wheel your question is impossible to answer.
Old Aug 3, 2011 | 07:24 PM
kemps's Avatar
kemps
He means 19x12
Old Aug 3, 2011 | 09:29 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you're going for a big lip, 3.5" is a joke especially having to run a wider than normal wheel. Look into different wheels... sounds like your setup is questionable at best.
Old Aug 3, 2011 | 10:47 PM
Jacob350z's Avatar
Jacob350z
19x12 has been done as stated above, be prepared for mega fender pull and max camber.
I ran 19x11-17 on my last setup. Its sexy but not worth the trouble. Just a FYI 3.5" lip is weak on a 12 width, my 11 in these pics have 6" lips.
Old Aug 4, 2011 | 05:28 AM
007gt's Avatar
007gt
19x12 +10 4.5 inch lip
Old Aug 4, 2011 | 10:29 AM
Jacob350z's Avatar
Jacob350z
My 11-17 is more aggressive than that 12 +10.
On another note the search engine is your best friend. Gl
Old Aug 5, 2011 | 09:54 PM
datsunHEAD's Avatar
datsunHEAD
so im guessing we should just make this a 19x11/19x12 thread
Old Aug 6, 2011 | 11:15 AM
MYN1SMO's Avatar
MYN1SMO
Old Aug 6, 2011 | 12:49 PM
-miltdoggie-'s Avatar
-miltdoggie-
Cornell.... That blue wheel is an 8" lip... I know since they are mine.
