wheel size question
Old Aug 15, 2011 | 01:25 AM
blktrack350's Avatar
blktrack350
Default wheel size question
i was just wondering if these wheels would fit on a track edition 350z with 15mm spacers. here are the specs on the wheels
Wheel Style - Rota Grid
Wheel Diameter (Inches) - 17"
Wheel Width (Inches) - 9.5"
PCD Bolt Pattern - 5x114.3
Offset - +30mm
Hub Bore - 73mm
just looking for something cheap and in 17's that still look good for my track setup.
Old Aug 15, 2011 | 03:11 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
why would you need the spacer at all?
Old Aug 15, 2011 | 03:23 AM
How come you dont know this?
Old Aug 15, 2011 | 09:46 AM
bmccann101's Avatar
bmccann101
OP has been waiting comfortably in his nest .... lurking the forum.
jk. had nowhere else to use this pic tho haha.
Old Aug 15, 2011 | 11:25 AM
JCITY's Avatar
JCITY
17's on a track?
Don't you have 18's on there now?
Old Aug 15, 2011 | 01:11 PM
terrasmak's Avatar
Originally Posted by JCITY
17's on a track?
17's are much cheaper to run on the track, many people run them. If you do some reading you may understand he owns a track edition and is buying these wheels for running on a race track.
17x.9.5 with 275/40 all around. Dependent on camber you can run a 15mm spacer up front and easily run one out back.
Old Aug 16, 2011 | 06:31 PM
blktrack350
because i am stupid. and have never looked into wheels.
Old Aug 16, 2011 | 06:32 PM
blktrack350
^ this
Old Aug 16, 2011 | 06:38 PM
Waiz's Avatar
Waiz
What suspension are you going to run? You will need to think about rolling your rear fenders if you add those spacers in the rear depending on your tire size.
You might also want to scroll down this post for more info on what the Z can fit and what is needed:
https://my350z.com/forum/2487452-post8.html
Old Aug 17, 2011 | 08:01 PM
blktrack350
thank you
DarkCreep
Oct 17, 2015 11:50 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
