Garson DR302 - Opinions Needed
Old Sep 9, 2011 | 11:55 AM
SnaggleToof's Avatar
SnaggleToof
Default Garson DR302 - Opinions Needed
Up for sale is a set of Garson DR302's locally. Great price, but curbed. gunna need to spend about $600 to get them fixed. Im not too worried about that.
What im worried about is fitment. Im not gunna be hellaflush or extremely low. Goal is for the fenders to be flush with the top of the tire or just a little tucked.
Here are the wheels, this pic is of the rear.
18x9 + 17
18x10 + 22
I used a offset calculator and found out these will poke out 26mm more in the front and 30mm more in the rear over my factory 03 Track wheels.
That should sit decently flush with the fender, no?
Another thing that was brought up to me was that the spokes would stick out too far and look silly... like the spokes arent sunken in enough...
thoughts?
Old Sep 9, 2011 | 12:00 PM
ZS14RR's Avatar
ZS14RR
no.
Old Sep 9, 2011 | 12:03 PM
SnaggleToof
Originally Posted by ZS14
no.
Wow great post buddy.
Old Sep 9, 2011 | 12:08 PM
verdict.'s Avatar
verdict.
Moved to Wheels & Tires...
Old Sep 9, 2011 | 12:09 PM
ZS14RR's Avatar
ZS14RR
i answered this question.
Old Sep 9, 2011 | 12:14 PM
SnaggleToof
Ok, so how sunken would it be?
With the stock track wheels i see people using 25mm front and 30mm rear spacers to make it sit a lot more aggressive...
If these wheels give me +26mm front and 30 rear... how would they not sit flush?
Old Sep 9, 2011 | 12:22 PM
ZS14RR's Avatar
ZS14RR
tire size?
Old Sep 9, 2011 | 12:25 PM
SnaggleToof
tire size?
i havent purchased tires yet... probably decide that after i buy wheels. Not sure what tire size has to do with rim offset or wheel spokes...
Old Sep 9, 2011 | 12:27 PM
ZS14RR's Avatar
ZS14RR
thats valuable information.
Old Sep 9, 2011 | 12:31 PM
SnaggleToof
ok well im gunna buy proper sized tires, not meaty but not stretched... ill have to research what size tires go on these widths...
Old Sep 9, 2011 | 12:38 PM
Classy's Avatar
Classy
I will be the guy who isn't going to flame you. I had 18x9.5 +15 in the front on my old rims, and they poked out alittle, but yours are .5 inches less wide and a touch more conservative. The rears will fit great I have 18x10 +25 and they fit great, I am going to roll flat my fenders and fit a 295 in the rear, those rims will fit great, best of luck on the newish rims!
Old Sep 9, 2011 | 12:41 PM
Classy's Avatar
Classy
Also, for tire sizes, you can run a 245 or 255 up front and a 275 in the rear, not meaty, not stretched just right for what you want
Old Sep 9, 2011 | 01:45 PM
Believe this will work. You will NOT be able to add a fat tire.
Old Sep 9, 2011 | 01:51 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
http://rimtuck.com/search/thumbnails...=18&widthr=10&
Use those setups and the offset calculator to figure out what you'll end up with. I prefer this calculator.
http://www.1010tires.com/wheeloffsetcalculator.asp
Old Sep 9, 2011 | 01:54 PM
Tire size will or will not allow you to tuck the tire under the fender.
Old Sep 9, 2011 | 01:55 PM
For wheel-tire width see: http://www.tiresandco.ca/equivalency-tables-advice.html
Old Sep 9, 2011 | 02:58 PM
Classy's Avatar
Classy
There is plenty of room to put a big tire in the rear, I have 18x10 +25 all around running 265/35/18 front and 275/40/18 rear, I plan on 275/35/18 front and 295/35/18 rear when I burn up these tires and I am here to tell you there is room
Old Sep 9, 2011 | 03:06 PM
huyrua's Avatar
huyrua
Does it come with center caps? They would look weird without them cause the double tapped/drilled lugs holes are ugly.
Old Sep 9, 2011 | 03:10 PM
SnaggleToof
Yeah they come with center caps
Old Sep 9, 2011 | 03:26 PM
Waiz's Avatar
Waiz
Yes they should be fine and I'm not sure how the spokes could stick out if they are inside the wheel well?
