New Volk GT-F's Need Help w Tire Sizing
Old Oct 15, 2011 | 07:53 AM
terrasmak's Avatar
Originally Posted by aXxICExXa
I would like to have the same wheel setup but 285/35 for my rear wouldnt work because I have TCS and the diameter change is over 3% so my TCS will randomly kick in because it will think the tires are slipping. Only thing in the 285 range that would work on my car is 285/30
WRONG, 285/30 will give you TCS problems with a 245/35 front, 285/35 rear will work just fine, other than the fact the car will handle like crap.
Old Oct 15, 2011 | 12:18 PM
ronn1's Avatar
ronn1
Like I said...275/35 is the one for the rear. Perfect match to stock diameter.
Old Oct 16, 2011 | 12:45 AM
Juci's Avatar
Juci
255/35 and 285/35 might be nice without lowering
245/35 and 275/35 with coils
Old Oct 17, 2011 | 07:17 AM
aXxICExXa's Avatar
aXxICExXa
Go to www.1010tires.com and then tell me im wrong about the 285/35/19.
If you look it will show you that 285/30/19 is the only tire setup in 285 range that isnt over the 3% diameter change over the stock tires.
Old Oct 17, 2011 | 10:46 AM
terrasmak's Avatar
3% rule is for a difference between front and rear tire height. The rear tire needs to be taller than the front. Typically 285/35-19 is combines with a 255/35-19 front, but it will work with a 245/35 front and as i stated "will handle like ***" can you say understeer?
As far the the rear upsize is concerned, 275/35 is ever so slightly shorter than OEM, and 285/35 is slightly taller than stock. Same goes with the 245/35 front and 255/35 rear.
All these measurements are made against the OEM tire sizes of 225/45-18 front and 245/45-18 rear. There are 2 other OEM tire sizes for a Z, (17's and the 18f 19R combo) but the difference is insignificant and the computer doesn't care.
SO YES YOU ARE WRONG, PLEASE TRY AGAIN.
Old Oct 19, 2011 | 07:04 PM
aXxICExXa's Avatar
aXxICExXa
Originally Posted by beezee
I have 245/35 and 275/35 with similar wheel sizes. Wish I had 255/35 and 285/35.
Why do you wish that? Does ur current setup handle bad or ride rough?
