19" 2009 maxima sport rims on 350z?
Old Jan 8, 2012 | 02:56 AM
xman2yman's Avatar
xman2yman
Default 19" 2009 maxima sport rims on 350z?
Hey just wondering if anyone has put those rims on the 350z and if so if they can post a picture. I've search with 0 results so far. If anyone is wondering what they look like check the link out thanks
http://www.socalwheels.com/view-prod...0-19/_#gallery
Old Jan 8, 2012 | 04:39 AM
lgear080's Avatar
lgear080
nice! those offsets are bangin!
Old Jan 8, 2012 | 04:54 AM
Looch's Avatar
Looch
oh my...
Old Jan 8, 2012 | 04:58 AM
huyrua's Avatar
huyrua
A used set of LMGT4 can be had for a couple of hundred dollars more
Old Jan 8, 2012 | 05:03 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
You would need 4-20mm wheel spacers to get them to 350Z factory offset specs.
Old Jan 8, 2012 | 07:22 AM
cubs4worldseris's Avatar
cubs4worldseris
absolutely not! for that price, a set of Enkei RPF1s can be had in friendly Z specifications.
Old Jan 8, 2012 | 09:23 AM
BoomerZ33's Avatar
BoomerZ33
not bad looking. but they're stock rims. you can find a decent set of jdm aftermarkets for that price.
Old Jan 8, 2012 | 10:31 AM
JCITY's Avatar
JCITY
Actually,I kinda like e'm.You would need spacers to get it right.
For the cash,these include used tires(not too keen on those Bridestones),I'd spent a bit more a get something a bit more unique.I prefer a wheel with nice lip...at least 2" in the rear rather than these.
Old Jan 8, 2012 | 10:45 AM
Its never been done before. Call yourself a visionary. A trailblazer.
Old Jan 8, 2012 | 12:35 PM
xman2yman's Avatar
xman2yman
haha thanx for all the comment guys, I actually put that link up just so people could see what they looked like and see the specs. I agree in regards to the lip and honestly would only considered these if they were the right price because for stock wheels i do still love the g35 Rays but am very curious to see how these would look on the Z.
Old Jan 8, 2012 | 01:51 PM
angelo350z's Avatar
angelo350z
It's not the look, offsets, or the fact that they're OEM wheels that's the problem. The wheels are just too narrow
Old Jan 8, 2012 | 02:44 PM
terrasmak's Avatar
The look cool, but the width sucks. They are only 8 inch wide front and rear, if i were to buy new wheels for a Z they will have a minimum width of 9 front and 10 rear. Next is offset, they will require a 30mm spacer to get them to OEM z specs. If you need more than a 20mm spacers, you are buying the wrong offset. For the $$ you can get a good looking wheel, that is wider , with a better offset.
Old Jan 8, 2012 | 03:05 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Winter wheels?
Old Jan 8, 2012 | 05:42 PM
Waiz's Avatar
Waiz
OP, how can you be on this forum for more than 2+ years and ask that a FWD vehicle's wheels can be applied to a RWD Z?
Read this thread:
https://my350z.com/forum/2003-2009-n...questions.html
You will find this info:
Q: What wheel sizes and offsets do I need?
A: Generally speaking, there are a LOT of different combinations that people are running on their Z or G.
Let's get the basics out of the way first: You need a lug pattern of 5x114.3, width between 8 and 11 inches, and diameter of 17", 18", 19", or 20".
Here are some of the more popular wheel and tire sizes (for good reason) that people put on their Z's. There is no "RIGHT" answer but there is a limit to how big or small you can go.
18" combination:
Front 18" x 8.5" , Offset +15 to +25, Tires 245/40/18
Rear 18" x 9.5" , Offset +15 to +25, Tires 275/40/18
(lower offset such as +10 in rear is possible but may require rolling)
Front 18" x 9.5" , Offset +25 to +30, Tires 255/40/18
Rear 18" x 10.5" , Offset +28 to +35, Tires 285/40/18 or 295/35/18
(lower offset such as +23 in the rear is possible but may require rolling)
19" combination:
Front 19" x 8.5" , Offset +15 to +25, Tires 245/35/19
Rear 19" x 9.5" , Offset +15 to +25, Tires 275/35/19
Front 19" x 9.5" , Offset +25 to +30, Tires 255/35/19 or 265/35/19
Rear 19" x 10.5" , Offset +23 to +32, Tires 285/35/19 or 295/35/19
(lower offset such as +23 or wider tires in the rear is possible but may require rolling)
From this, you get the idea of what is required to go with smaller wheels like 17's, (typically lighter, faster acceleration), or bigger wheels like 20's (bigger, heavier, usually makes you feel slower).
Get to know how to use the following tools and you will be able to figure out for yourself the correct offsets and tire sizes you need:
Tire size calculator (click)
Wheel Offset Calculator
Certain combinations of LOW OFFSET and/or WIDE WHEELS will require what is known as "fender rolling" or "fender cutting".
If you are not familiar with the term "fender rolling", here is a quick but useful lesson you can learn in a couple of minutes: Go outside to wherever your Z is parked. Run your fingers along the inside edge of a REAR fender just above your tires. You will feel a sharp edge and a flap of metal sticking inward towards the car. Now, go up to the FRONT fender, and feel the inside of the fender again. You should notice that the flap of metal has been "rolled" upwards on the front fenders. This is exactly what fender rolling is all about. The rear fenders will need to be rolled to make room for wide wheels or low offsets, or else your tires may rub on the metal when you take hard corners or hit bumps. Any experienced wheel/tire shop should know how to roll a fender. If you go to a shop that does not seem like they know what they're doing, get out of there.
Old Jan 8, 2012 | 07:22 PM
xman2yman's Avatar
xman2yman
I was once again more curious in regards to what it would look like. I did notice the 8 inch wide thing and knew that wouldn't work to well but again was more curious of the look.
Old Jan 8, 2012 | 08:06 PM
Waiz's Avatar
Waiz
Offsets, not width are the problem....
Old Jan 9, 2012 | 02:38 AM
xman2yman's Avatar
xman2yman
Default Maxima wheels on Z
just wish to thank everyone with their replies in regards to my earlier question about 19" maxima rims on the Z, I dont know what happen to my post, guess it was deleted, thanx anyway.
Old Jan 9, 2012 | 02:48 AM
midz350's Avatar
midz350
You're welcome. See you in three months.
Old Jan 9, 2012 | 10:58 AM
bmccann101's Avatar
bmccann101
Old Jan 9, 2012 | 12:02 PM
Waiz's Avatar
Waiz
lol at last two replies
