Need some help from some wheel Guru's
Old Feb 18, 2012 | 06:12 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
If you go with 18x9+25 in the front and 18x10.5+20 rear, you will be fine...depending on what size tires you use. If you still plan on reusing the tires you have, I wouldn't mount a 255 tire on a 9" wheel because the tire is an inch wider than the wheel itself. Anyhow, I would start asking other 526 owners in the link I posted above.
Old Feb 18, 2012 | 06:37 AM
Originally Posted by lucasbroderick
http://www.ebay.com/itm/18x9-XXR-526...item1c2237d0ab
Can I get some advice on these?
I know that they don't quite fit what I was explaining, but I love the big lip. Wondering if there's any red flags about this set.
That will work. You can run 235 to 265 mm tires and you will be fine.
Old Feb 18, 2012 | 01:29 PM
lucasbroderick's Avatar
lucasbroderick
In all likelihood I'll be ordering those. Can't wait to put those badboys on my car.
Old Feb 22, 2012 | 05:58 PM
lucasbroderick
Just wanted to let everyone know that I purchased the XXR 526 in Gloss Black, 10.5 inch and 9 inch staggered. I'll be posting pics up as soon as they're installed. Thanks for all the help!
Old Mar 9, 2012 | 11:20 AM
lucasbroderick
Pictures, as promised:
Before
After
Old Mar 10, 2012 | 09:20 AM
Phenom's Avatar
Phenom
Toasty
You should have bought 6 wheels so you'd have a couple extra for when these wheels bend also.
Old Mar 10, 2012 | 07:47 PM
lucasbroderick
Are they prone to bending?
Old Mar 10, 2012 | 08:44 PM
terrasmak's Avatar
Now you just have to order the proper rubber for your car. 265/35 is a great front tire.
Old Mar 11, 2012 | 07:16 AM
lucasbroderick
I tried running 265 on my old set in the fronts, and the shop told me that they were too wide. 255's worked, however. The fitment of the front is pretty good, but the back is a bit more a gap between the rim and the tire than desired. Maybe a 285 width would do better?
Old Mar 11, 2012 | 11:25 AM
terrasmak's Avatar
First find a new shop, and yes a 285/35 would be better out back, then move your 265/35 to the front.
I will put $20 on it saying the 265's will fit up front and not rub with those wheels.
Old Mar 11, 2012 | 03:34 PM
Waiz's Avatar
Waiz
Closing since you made your decision
If you have any other questions regarding these wheels you can search first or post in the XXR thread
