lug nut help!!!
Old Mar 7, 2012 | 06:47 AM
350zeed's Avatar
350zeed
Default lug nut help!!!
Is the 2003 lug nut pattern different then others? I bought 12x1.25 cause I read that is what our cars use. So I sold my old set, and bought the said bolt pattern. Well now these don't fit. I guess I should have checked the old ones to see.. but can anyone solve the mystery?
Old Mar 7, 2012 | 08:31 AM
DavesZ#3's Avatar
DavesZ#3
Nope, been the same on all 350Zs. Are you the original owner? If not, is it possible the previous owner replaced studs (can't imagine why someone would change size/pitch though)?
Old Mar 7, 2012 | 08:48 AM
350zeed's Avatar
350zeed
No I'm not the original owner
Old Mar 7, 2012 | 08:54 AM
KornerCarver's Avatar
KornerCarver
My '03 has the 12 x 1.25..........
Old Mar 7, 2012 | 09:17 AM
350zeed's Avatar
350zeed
Odd, I should be able to take a lug off and check it at advance or auto zone right? I'm with u #3 why would someone change all 20 studs
Old Mar 7, 2012 | 09:47 AM
ridered929rr's Avatar
ridered929rr
Did you take the dummy post off the front?
Old Mar 7, 2012 | 10:10 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Maybe because that's all they had available in the right length. Either way, kinda foolish.
You can buy a thread pitch gauge to check the TPI (threads per inch). You're confusing the term with "lug nut pattern" with "thread pitch." You're bolt pattern (lug nut pattern) aka PCD is 5x114.3mm. What you're trying to figure out is your lug nut specs, which include diameter and thread pitch.
Old Mar 7, 2012 | 11:31 AM
350zeed's Avatar
350zeed
I thank you guys for the help, buahhh you ready for this.... The on stud I tried it on, out of all 20, was jacked up, I'm sorry for the inconvenience. It is 12x1.25
Old Mar 7, 2012 | 12:32 PM
ronn1's Avatar
ronn1
Ya mean you didn't suspect it was cross threaded and trashed??
Old Mar 7, 2012 | 01:37 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Haha that's funny. At least you figured out what the issue was!
Old Mar 8, 2012 | 05:25 AM
350zeed's Avatar
350zeed
I ment the one stud I tried it on... No I didn't suspect it to be cross threaded or anything
Old Mar 8, 2012 | 08:52 AM
Zoom750's Avatar
Zoom750
I have new studs if you need them.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
