will i be ok quick help with size ?
Old Jun 23, 2012 | 08:49 AM
R350Zz33's Avatar
R350Zz33
Default will i be ok quick help with size ?
275/40/19 245/35/19
are these ok to run ? i dont have vdc
Old Jun 23, 2012 | 09:01 AM
terrasmak's Avatar
Originally Posted by R350Zz33
275/40/19 245/35/19
Nope, try 275/35,
Old Jun 23, 2012 | 09:19 AM
R350Zz33's Avatar
R350Zz33
Nope, try 275/35,
will it rub?
Old Jun 23, 2012 | 09:58 AM
-Trav-'s Avatar
-Trav-
will it rub?
Ive seen it done, but its super tall. Rubbing depends on ride height and offset. Your tire will be 1/2" closer to the fender, plus your ride height will go up 1/2". Plug these numbers in to your setup, check clearances and go from there.
Old Jun 23, 2012 | 10:15 AM
R350Zz33's Avatar
R350Zz33
just called the guy im gonna do a test fit the rears are 19X10.5 +12
Old Jun 23, 2012 | 12:49 PM
JCITY's Avatar
JCITY
Thumbs up
Nope, try 275/35,
256/35/19 would be better
Old Jun 23, 2012 | 01:02 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
If you don't have VDC you can run whatever size you want. What are your concerns?
Old Jun 23, 2012 | 01:55 PM
R350Zz33's Avatar
R350Zz33
Will it rub with that rim there pilot p2's
Old Jun 23, 2012 | 04:07 PM
Waiz's Avatar
Waiz
Read the top 100 FAQ, post #8 and this is clearly explained
