18x9 Front and 19x9.5 rear?
Old Sep 4, 2012 | 06:56 AM
Zach1123's Avatar
Zach1123
Default 18x9 Front and 19x9.5 rear?
So I came across an awesome deal on a set of wheels and I've been looking through old posts about tire sizes, vdc, offsets, and all the other factors that come into play on the Z. Just to sum things up real quick... I'm looking at a set of 18x9, and 19x9.5 with a 24mm offset in the front, and a 35mm offset in the rear. Basically I'm looking for clarification on.
A: I'm going to need small spacers in the rear to sit somewhat flush?
B: 245/40-18 and 275/35-19 should give me no stretch, clearance, somewhat equal sidewall height, and should allow a less than 3% variance from stock so I won't have issues with the VDC/TCS?
C: Will work with a small drop such as Tein S-Tech's.
I've run through this setup several times and I'm just looking for some reassurance that I'm not missing anything, and all the sizes will indeed work together. I'd really hate to order all of this and have one of those moments when I go to put the wheels on the car. lol
I also looked around for photos of a 18/19 setup and found very few. If anyone can post up a few pics, or supply me with a link to a thread that I may of overlooked I'd appreciate it.
Thanks!
Old Sep 4, 2012 | 07:39 AM
terrasmak's Avatar
Great idea and setup, but you will probably want a 20mm rear spacer.
Old Sep 4, 2012 | 07:45 AM
Italianjoe1's Avatar
Italianjoe1
Almost the same as the stock GT/Nimso setup, except the rear is a 19x10. I think the offsets are almost the same too.
Old Sep 4, 2012 | 08:52 AM
Bmurray350z's Avatar
Bmurray350z
going to be sunken in a good amount. i'd save and get a set of wider wheels so that you don't have to buy spacers and mess with all that
Old Sep 4, 2012 | 10:01 AM
Zach1123's Avatar
Zach1123
Yea I was thinking the same thing... But with the huge savings that I'm getting on the wheels. I think I'll bite the bullet and just throw some spacers on the rear. lol
Thanks for the replies!
Old Sep 4, 2012 | 10:18 AM
ZS14RR's Avatar
ZS14RR
Crappy fitment and spacers. Just get replicas
Old Sep 4, 2012 | 10:20 AM
Bmurray350z
go for it then!
if you're going for that "flush/semi-flush" look, you will need 15-20mm spacers on all 4 corners.
Old Sep 4, 2012 | 10:31 AM
Highway Riding's Avatar
Highway Riding
Stock Nismo's come with some thing close to this setup! Not hard to see what they'll look like.
Old Sep 5, 2012 | 11:00 AM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Definitely think an 18/19 stagger could look really good, but if you're trying to make it pretty flush you'll need some spacers.
