Getting Chrome Paint off of my wheels.
So I am attempting to paint my wheels and read all of the threads about how to prep. My wheels are steel and are chrome painted. I read that you have to sand it first (320) but it seems like the paint is barely coming off. Wouldn't using paint thinner, nail polish remover (with or without acetone) be easier to do first to get most of the paint off THEN sand the wheels?
1. Those are aluminum wheels
2. Chrome isn't a painted finish, its three layers of metal coating. Copper/nickle/chrome
3. Paint doesn't like to stick to chrome, even when sanded down it's too slick to hold over time.
Your best bet is to keep them chrome (you're fuct if you started to sand them down already) or sell/trade them for a wheel you like. Everyone like to mod parts/cars but rule number one is knowing exactly what you're working on. Rule two is in my signature.
Edit: The only way to remove the chrome finish is to give an acid bath, the type the chroming facilities use. Not a process you can home brew and not recommended for wheels. A strip and re-chrome makes a wheel much more bristle and subject to cracks down the road.
Thanks for the advice. I am actually planning on buying a new pair of wheels in a few months but just wanted to experiment with these for now. Supplies aren't very expensive and I would get a new set later anyways so wouldn't really be a loss to me.
Just read your edit and will probably not go through with it if that's the case. Should I just plastidip the wheels then?
EDIT: WOULD plasti dip work on chrome finished wheels?
I have Touring V2s on my car which are my favorite Z wheel but sadly they came chrome dipped as well.
At first I wanted to plastdip them white, but after seeing all these kids ruin their cars with Plastdip I decided to hold off till I get a decent set of wheels.
Post before and after pics!
My wheels before the plasti dip were disgusting as you can see by my pics from my past post. You can see all that dirt and grease that's hard to get off. With the plasti dip it looks a lot cleaner but this was my first time using any type of spray paint to paint something so it came a little uneven but nonetheless happy with the result. Wished I did 1-2 less coats of the gold to make it brighter though. The picture with the close up of the plasti dipped wheel was by far the worst out of all the other wheels.
I have no opinion on what color one uses to paint wheels, but the method used to masked them before painting seems clever. Never though of playing cards stuck between rim and tire. Is that something recommended by the plasti-coat people or an original idea? Just one more question, does the slight offset of one playing card behind another show in final paint job or does one get a seamless result around the rim?
