TPMS not showing up on gauges
Old Jul 8, 2013 | 06:09 AM
rorad's Avatar
rorad
Default TPMS not showing up on gauges
I had new tires put on about 4 months ago. Didn't notice at first but went to check the tire pressures and its as if my car doesn't have a TPMS system. Absolutely nothing on the gauges showing tpms at all not even tpms --:--. I did remove my center console to repaint so maybe I did something but everything else works fine. No lights are showing up on my instrument panel either.
Old Jul 8, 2013 | 06:19 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Do you have TPMS on your wheels?
Old Jul 8, 2013 | 06:23 AM
rorad's Avatar
rorad
Yes, it's a touring roadster and the tpms status showed up before.
Old Jul 8, 2013 | 06:25 AM
AdvanZ33's Avatar
AdvanZ33
What I'm getting at is did the tire shop replace your sensors with regular valve stems when changing your tires?
Old Jul 8, 2013 | 07:30 AM
l2iceman's Avatar
l2iceman
Originally Posted by rorad
I had new tires put on about 4 months ago. Didn't notice at first but went to check the tire pressures and its as if my car doesn't have a TPMS system. Absolutely nothing on the gauges showing tpms at all not even tpms --:--./ I did remove my center console to repaint so maybe I did something but everything else works fine. No lights are showing up on my instrument panel either.
Bolded parts above...you say that nothing shows up on the gauges, not even "--" and no lights are showing on your instrument panel...I would say to take apart the centre console and make sure you plugged everything in correctly?
