PSA: When asking "will this rub"....
Old Dec 30, 2014 | 03:50 PM
  #41
travlee's Avatar
travlee
Master
i THINK you will be okay with those offsets and sizes, not too aggressive but someone else will need to chime in (i know more about 18s)
Old Dec 30, 2014 | 04:20 PM
  #42
RUNWDVL's Avatar
RUNWDVL
It'll fit. I'm running 19x9 22 with 265/35 front and 19x10 15 with 295/30
Old Feb 9, 2015 | 01:59 PM
  #43
RENFRO's Avatar
RENFRO
Rear:
305/30
19x10.5 +18
Lowered and fenders rolled.
Front:
275/30
19x9.5 +17
Any clue on if I'll have major issues? I know I had about 3-4mm of clearance when I was running 295s out back on a set of 10.5in 18s with a +15 offset. It'll be tight and may require some extra camber...thoughts?
Old Feb 12, 2015 | 12:44 PM
  #44
midz350's Avatar
midz350
This site has a lot of pictures for different set ups. Very helpful. http://www.rimtuck.com/search/thumbn...&sort=3&page=1
Old Feb 12, 2015 | 06:20 PM
  #45
nizmo_0385's Avatar
nizmo_0385
2007 350z nismo.
Not rolled.
Lowered on eibach sportline
camber rear is -3.6 for now.
Thinking of running
19x9.5 et30 front 265 35
19x10.5 et30 rear 285 35
Will I rub. Will I need to roll?
Old Feb 17, 2015 | 12:15 PM
  #46
Fridge Gnome's Avatar
Fridge Gnome
New to all this, I'm buying some new wheels and I want to make sure I don't make any dumb mistakes.
08 350z
No lower, no roll
18x8.5 +25 225/45
18x9.5 +15 245/45
Old Feb 17, 2015 | 12:17 PM
  #47
travlee's Avatar
travlee
Master
08 350z
No lower, no roll
18x8.5 +25 225/45
18x9.5 +15 245/45
you will be fine with those... you can do a 9.5+23 and not rub in the front (my hr ran that size, but i have DE friends running a +15 in front)
Old Feb 18, 2015 | 10:34 AM
  #48
jbh1's Avatar
jbh1
Default 10.5 RFP1 on 285 RS3 all around on stock suspension, will it rub?
I did it know exactly where to post this but as the subject says I have 10.5" with 15 offset RFP1 wheels with 285 rs3 on them. I still have stock suspension but rear fenders are rolled. Will this rub or damage my front fenders? They are on my car in the garage now and the front tire sticks out past the front fender like a jeep but I have not driven on them yet. I was hoping someone had tried this before.
I plan to run an autocross Sunday so I will have full compression on the suspension. I have stock camber also, all stock 03 350z. Want to run it this way once before the new suspension goes on if possible.
I am awaiting my ohlins to arrive and have the adjustable camber arms ect so it will be built properly for autox in a month in STU classand I know the wheels will work with the new suspension and aggressive camber.
Old Feb 19, 2015 | 10:46 PM
  #49
terrasmak's Avatar
they will probably touch a bit near full compression. I wouldn't chance it, just install your front arms and add a hair of camber if you already have them. It will also save your tires
Old Feb 20, 2015 | 03:50 AM
  #50
jbh1's Avatar
jbh1
Thanks!
I'll do that. Thanks for your help.
Old Feb 20, 2015 | 10:40 AM
  #51
Folt's Avatar
Folt
Will it rub?
9.5 + 12 Front
10.5 + 15 rear
I can roll fenders, but do not want to camber if possible.
2003 350z non brembo, lowered on tein springs.
tire size is still undecided depending on fitment. (what do you think will work for me?)
Old Feb 21, 2015 | 03:13 AM
  #52
terrasmak's Avatar
Originally Posted by Folt
Will it rub?
9.5 + 12 Front
10.5 + 15 rear
The wheels won't, but your tires can depending on size
Old Feb 21, 2015 | 06:16 AM
  #53
Folt's Avatar
Folt
What tire size would you recommend? Im still shopping for tires anyways
Old Feb 23, 2015 | 02:12 PM
  #54
Folt's Avatar
Folt
Would 245/35 Front / 275/35 Rear tires rub with the previous wheels I mentioned?
Wheels: 9.5 + 12 Front
Tires: 245/35
Wheels: 10.5 + 15 rear
Tires: 275/35
Will that rub on a lowered Z with rolled fenders?
Old Feb 24, 2015 | 09:10 PM
  #55
knuckle350z's Avatar
knuckle350z
Stock 350Z enthusiast 2007
ES2 19x8.5 +35 offset
ES2 19x9.5 +22 offset
interested in running 245/35/19 Front
and running 275/35/19 back
Was thinking maybe Mich SuperSports.
Will this work? And if it does, anyone have suggestions for a best performance fit?
Old Feb 24, 2015 | 10:42 PM
  #56
03Lemans350z's Avatar
03Lemans350z
Default fitment question
I am going to buy 19" vordoven forme 1 rims 9.5 front, 10.5 rear. And offset of 22mm front 22mm rear. My car is lowered 1 inch on springs. And my fenders are not rolled. I will roll them if need be. As for tires I'm leaning towards falken fk452. 255/35/19 front and 275/35/19 rear. If anyone could tell me if this setup will fit properly or if I need a different offset or tires sizes I would greatly appreciate it. As far as I know these should fit. And i think I could even have up to 15mm offset.
Old Feb 25, 2015 | 06:26 PM
  #57
terrasmak's Avatar
Rears may need a hair of a roll, depends on where in the OEM camber range you car is at
Tires: 245/35
Tires: 275/35
You will need to roll the rear and trim the fender liner screw up front.
Old Feb 26, 2015 | 06:50 AM
  #58
iideadeyeii's Avatar
iideadeyeii
08 350z
No lower, no roll
18x8.5 +25 225/45
18x9.5 +15 245/45
Your tire width is the only mistake you're making
Old Feb 26, 2015 | 09:46 AM
  #59
Folt's Avatar
Folt
Thanks for your opnion, are you 100% certain about this? My purchase decision is literally depending on the confidence of your opinion haha.
Old Feb 26, 2015 | 09:57 AM
  #60
terrasmak's Avatar
All cars are slightly different and different tires are actually different width. Results can be off by a hair or two, if off you may require front camber arms to get rid of the rub.
