5x114.3 to 5x112 wheel adapter HELPPP
Old Aug 23, 2013 | 09:20 AM
Melloyellow's Avatar
Melloyellow
Default 5x114.3 to 5x112 wheel adapter HELPPP
hey guys I need some serious help with this issue here as I am somewhat of a noob to wheels spacers and specs. I am trying to run my friends 5x112 wheels on my 350z and would like to use adapters to lower the offset as well as make the wheels able to fit. I am confused as to how many sets of lugs I need because some say open ended lugs are needed as well as additional lugs. Als do I need to match the hub diameter etc.
Old Aug 23, 2013 | 09:50 AM
terrasmak's Avatar
Please post all the specs , front and rear wheel size, width and offset , then tire size.
Old Aug 23, 2013 | 10:00 AM
Waiz's Avatar
Waiz
No way to even ensure that you can run the wheel on our cars without that info
Plenty of people have run adaptors on our platform but the wheels were rare and worth the effort
Old Aug 23, 2013 | 11:11 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
More info would be nice but I can answer the above quoted:
-You'll need 20 lug nuts to hold the adapters in place then another 20 lug nuts to hold your wheel in place.
-Matching the hub diameter is always recommended/preferred. Use of hubcentric rings may be necessary.
If you can provide more info as the guys above asked, then they should be able to help you out with the exact fitment. My reply above only answers your question in a general sense.
Old Aug 23, 2013 | 11:46 AM
shadow191's Avatar
shadow191
Most of the adapters I've seen work like bolt on spacers. So they'll come with very low profile nuts that bolt the adapter to the stock lugs. Then you just use regular lugnuts on the new bolts. Depending on the wheel design, you may or may not be able to use adapters. If pad on the wheel won't accomodate the stock lugs, then it won't work. Keep in mind that the stock lugs stick out past the adapter, so the wheel still has to clear.
If the adapter won't work, you could redrill. 5x114.3 to 112 is a very small difference. Or, and probably the least appealing option, you can run wobble bolts. But all of this is only if the wheel is worth it and one that you can't go find in the right bolt pattern.
