350z 2003 18inch oem wheels can I use 370z wheels
Old Nov 24, 2013 | 12:25 PM
outlaw9259's Avatar
outlaw9259
Default 350z 2003 18inch oem wheels can I use 370z wheels
Hi guys I have had my z for 10 years now and wanted some change can't change the car ATM $$ but I heard changing the rims gives the car a new look
I have read a lot of post still not clear as if you spacers for the 370z 19inch rays for a 350z 2003 are needed I am trying not to use spacers because I read how dangerous it can be from my research I can put any rims oem 2003-2009 if I am correct but not sure about the 370z if the 19icn don't work how about the 18inches for the 370z
Thanks for any inputs
Joe
I have ATM the 350z 2003 with 2003-2005
Aluminum Alloy
Front
Offset: +30mm
Weight: 26.56lbs
Tire: 225/45-18
Rear
Offset: +30mm
Weight: 26.56lbs
Tire: 245/45-18
Old Nov 24, 2013 | 05:08 PM
JCITY's Avatar
JCITY
Are you dead set on the 370 Rays wheels?
Pretty common looking.
I've got 19's,no spacers on my 03.+20 offsets.They fit&look great.
19's IMO are the best for a design balance on the 350.Go with 18's if youplan to
track your car.19's for regular DD driving.
Old Nov 24, 2013 | 05:44 PM
nextcore's Avatar
nextcore
it should fit fine.
people run spacers for the flush look. if you plan on just daily driving the car, spacers are fine as well. ive heard horror stories about spacers "failing" but there are tons of people that run spacers without issues.. and the horror stories come from people who either installed them improperly or have improper supporting studs or lug nuts.
Old Nov 25, 2013 | 01:39 PM
outlaw9259's Avatar
outlaw9259
Thanks for the info now I have more rims to choose from lol thought I had to stick with the 350z rims
Old Nov 25, 2013 | 04:25 PM
hellman_x's Avatar
hellman_x
You will need spacers for the front.
Old Nov 25, 2013 | 10:01 PM
Waiz's Avatar
Waiz
Your post is one long rambling sentence so it is hard to understand your question
What are the specs of the wheels you are trying to run? The ones you have listed?
Unless you are willing to run the 19" 370z wheels the 18" 370z wheels are not worth changing out
Edit:
There is also already a thread with plenty of examples of 370z wheels on our cars:
https://my350z.com/forum/wheels-and-...s-on-350z.html
RiujinZero
Apr 16, 2021 11:31 AM
Siqcology
Sep 18, 2019 01:45 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
FromGtoZ
Sep 20, 2015 03:41 PM
RWDBajan
Sep 8, 2015 06:25 AM
