Help, Stretched tires on rims?
Old Dec 20, 2013 | 09:52 PM
zdriftergrl's Avatar
zdriftergrl
Question Help, Stretched tires on rims?
My 2006 350z has 225/45/18 on the front and 245/45/18 in the back. I ordered rims that are 8.5/18" in the front and 10/18" for the rear. Can the tires be stretched to fit on the rim okay? We already have rolled fenders.
I really would like to keep the tire size the same because of money issues but also because I like the rolled tire look.
Thanks
Old Dec 21, 2013 | 01:54 AM
The wheel is 254 mm wide. The tire is 245 mm wide. Why would this not work?
Old Dec 21, 2013 | 02:24 AM
terrasmak's Avatar
Simple and easy, and with those specs, still pretty safe
Old Dec 21, 2013 | 05:16 AM
winchman's Avatar
winchman
The 18x8.5 inch rims are OEM for the rear of the '08, and there's a stud on the front hub to keep you from installing them on the front of the car.
Any idea why they would do that??
Old Dec 21, 2013 | 05:28 AM
Because Nissan does not want you missing up the OEM wheels.
Old Dec 21, 2013 | 12:07 PM
POS VETT's Avatar
POS VETT
225 on 8.5" and 245 on 10 are easy. To check whether a certain tire of a certain size fitting on a given wheel width, check the tire manufacturer website. Most of them will have tables showing recommended wheel widths.
Old Dec 21, 2013 | 01:08 PM
travlee's Avatar
travlee
Master
to keep idiots from putting rears on the front and vice versa
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
