Help! I want to buy a very wide wheels LXZ. Will not rest on the slide wheels ?
Old Dec 23, 2013 | 01:10 AM
Evskyy388's Avatar
Evskyy388
Default Help! I want to buy a very wide wheels LXZ. Will not rest on the slide wheels ?
Greetings from cold Siberia friends! I want to buy agressive wheels Kranze LXZ (! FR!). http://kranze.jp/lxz.html
My car Nissan Firelady 350z ( 2003). On my car (350z) established normal / simple (thin)caliper (simple factory brake systems) .
*I want to buy wheels with the following parameters:
Set of 4 wheels:
P.C.D: 5 holes x 114.3
Front: (FR) r19, 10.5JJ, ET (offset) "-13", Inset 119mm (Ws-Lo), x 2 wheels;
Rear: (FR) r19, 12JJ, ET (offset) "-7", inset 131mm (Ws-Lo), x 2 wheels;
or these:
Front: (FR) r19, 10jj, ET (offset) "-7" inset 106mm (Ws-Lo)
Rear: (FR) r19, 11.5jj, ET (offset) "-13" inset 131mm (Ws-Lo)
Advice please :
1) Would the wheels with such parameters (Ws-Lo) balk ( face , be a hindrance ) to the standard / simple caliper ? I do not want to put spacers ! - because that drives and so are very aggressive ! Otherwise they will stick out from under the strong wing ... (
That way the dealer threw me this table :
________S-Lo___________WS-Lo
20inch__ 40mm__________ 31mm
19inch__ 40mm__________ 31mm
18inch__ 40mm__________ 31mm
Diller wrote what the difference between them : " Here is a table which shows the height of the central part millimertah . Higher central part of the larger the suppporty compatible. If calipers abut the drive you will have to put a spacer which would not want to , although there is nothing wrong .. "
But I do not want to put spacers ! ! Wheels agressianye very much! Spacers can not !
Consult me ​​please ...
Sorry, I do not speak English. I use Google translator.
Old Dec 23, 2013 | 05:31 AM
DCJodon's Avatar
DCJodon
All of those sizes are okay and will not hit non-brembo brakes. No need for spacers. I advise you know what you're doing before purchasing wheels that aggressive. You will need to roll and pull fenders on all four corners and purchase appropriate suspension parts for camber and toe.
