FI and tires....the hunt for traction!
Old Feb 20, 2014 | 06:12 AM
Dubai's Avatar
Dubai
Default FI and tires....the hunt for traction!
Looking to change my tires.....I'm at 450whp and have more room to crank up my boost to bump hp to 500+whp.
I tried the R888 but they are super noisy and very short life. RE11 is not available in my country.....I need street tires with reasonable price.....what do you guys think of Nitto Invo 305/30/19 ? If I go with that size in rear which size shall I use in front to match?
Old Feb 20, 2014 | 11:46 AM
jdm-v35's Avatar
jdm-v35
id go 265/30/19. not an extreme stagger and almost a perfect diameter match so as not to throw vdc off. Also if you want sticky tires, theyll always have a short lifespan. its a sacrifice; grip for tire life. cant have both.
Also pretty sure this is posted in the wrong section and should be in wheels/tires not FI.
Old Feb 20, 2014 | 11:54 AM
midz350's Avatar
midz350
Michelin pilot super sport if you want street tires. Supra guys love them.
Old Feb 20, 2014 | 11:56 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Tires aren't magic, upping the tire size isn't gonna magically increase grip. learning to launch helps ease getting power to the ground.
What is your current tire setup first off?
Old Feb 20, 2014 | 12:32 PM
Zivman's Avatar
Zivman
Originally Posted by midz350
Michelin pilot super sport .
I think this where you want to look. expensive though
Old Feb 20, 2014 | 02:24 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
+1 for the Michelin Pilot Super Sport if you want a relatively quiet street tire that performs very well. Tirerack.com ranks it #1 in the max performance summer category.
http://www.tirerack.com/tires/survey...ay.jsp?type=MP
I have Pilot Super Sports on my DD 370Z and I love them. Much better than the OE Bridgestone RE050A tires. FYI... The Nitto Invo is an ultra high performance summer tire, which is a category step down from the max performance summer tires.
As for your front sizing question... I have 305/30-19 on the rear of my G35 and 255/35-19 on the front. The diameter is within specs for the VDC and this setup worked well for me on a road course track.
Old Feb 20, 2014 | 05:36 PM
str8dum1's Avatar
str8dum1
r888 are far better than the pilot super sports.
i run Nitto 555RII with good results.
Old Feb 20, 2014 | 08:53 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Of course the R888 has better grip. But the OP indicated that they were too noisy and that the tread life was too short for his liking. So if the OP wants a more "civil" street tire, the PilotSuper Sport would be a good choice (and a superior choice to the Nitto Invo he's considering).
Old Feb 20, 2014 | 10:52 PM
Dubai's Avatar
Dubai
PilotSport tires are $420 each in my country so it's out of the equation.
Would the 255/35/19 or 265/30/19 be a better match for the rear 305/30/19 ?
Btw my wheels setup is 9.5/10.5
Old Feb 20, 2014 | 10:53 PM
terrasmak's Avatar
305/30-19 a hankook RS3 , is going to be one of the best tires you can get for a combo of wear vs traction. The Invo is a great tire, but you will easily blow them off with your power.
Old Feb 20, 2014 | 11:25 PM
midz350's Avatar
midz350
Have you checked with Sub-Zero or Alpha Logic?
Old Feb 21, 2014 | 05:26 AM
Dubai's Avatar
Dubai
Way over priced in local tuning shops.
Old Feb 21, 2014 | 06:58 AM
eZg's Avatar
eZg
barely OT .......
I'm in the same rwhp area and need to decide on wheels/tires.
At what point do you guys think widening up the front width of wheels/tires has too much of a negative effect on handling? emailed Ravspec and asked and was just referred to 370Zs running 11" rears and 10' fronts (I think)
I was thinking of going 19" x 11" on back. prob not much difference between 9.5 or 10" on fronts depending on what wheel sizes are available from manufacturer, eh?
sort for Semi-thread jack
George
Old Feb 21, 2014 | 07:05 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Then your thread title should be changed to "FI and tires... the hunt for CHEAP and QUIET traction with long tread life".
You can't have it all. You have to compromise in one aspect or another in this case. BEST TRACTION, QUIET RIDE, LONG TREAD LIFE, or CHEAP. <--- Pick 2.
Old Feb 21, 2014 | 07:16 AM
steven350's Avatar
steven350
Can't wait to test out my re-11
Old Feb 21, 2014 | 07:18 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Regarding 255/35-19 vs 265/30-19 on the front wheels in combo with 305/30-19 at the rear... 255/35-19 is the same or within .1" of the overall diameter of the OE front tire fitment (26.1"). The 265/30-19 is signicantly shorter (25.3") and could cause VDC issues.
Old Feb 21, 2014 | 07:30 AM
Dubai's Avatar
Dubai
As I said in my first post I'm looking for 'reasonable' tires that can fit the budget not the cheapest. I do understand that there is a compromise. Let's put it this way, I'm certain that I will be going with Nitto Invos as I tried them on my Z06 and they did the job at 580hp.
My next question is which size to go in front to match the 305/30/19 rears?
Old Feb 21, 2014 | 07:43 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
^^ I answered your question about the front sizes.
Old Feb 21, 2014 | 08:58 AM
Dubai's Avatar
Dubai
Sorry I skipped your post....thanks for the info
Old Feb 21, 2014 | 06:46 PM
terrasmak's Avatar
You know it is the percentage from front to rear , not from aftermarket to OEM that is important right? 265/30 would actually be a better choice do to the 305/30 being shorter than OEM too.
