Will I need another camber/alignment adjustment?
Old Apr 23, 2014 | 01:21 PM
BlazinCaucasian's Avatar
BlazinCaucasian
Default Will I need another camber/alignment adjustment?
Question for you guys. My car is at my mechanics, which is a little over an hour from where I live. I have 9.5/10.5 rp1's +15 w 265/35/18 & 285/35/18 waiting to go on. Im lowered 1", so I assume I will need a rear fender roll, which will be done over an hour from the mechanics. He just put in a spc rear camber kit, and eibach springs, which obviously calls for an alignment. So my question is this; could I take the rpf1's to him and let him get everything all aligned and camber in spec, and then bolt on the stock wheels just to get home and get the fenders rolled? Or will I need another alignment from doing that after I put the rpf1's back on. Dont care about what happens to the tires on the stocks. thanks
Old Apr 23, 2014 | 05:23 PM
Willis cabbage's Avatar
Willis cabbage
You will be fine, the wheels won't effect your alignment
Old Apr 23, 2014 | 05:27 PM
350ZZJoe's Avatar
350ZZJoe
+1
Also, good choice on the wheel/tire setup. I'm running the exact same
Old Apr 23, 2014 | 05:53 PM
terrasmak's Avatar
I would align it with your FPF1's installed. In theory it won't effect alignment but is slightly does do to the extra load on the bushing from the improper offset.
Old Apr 24, 2014 | 07:26 AM
BlazinCaucasian
Thanks, just wanted to make sure it wouldnt mess with it too much. In a bit of a time crunch trying to get alot done before zdayz
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
