Brake locked up
Old Jul 18, 2017 | 12:11 PM
Zclumpy's Avatar
Zclumpy
Originally Posted by Atreyu'z 350
No.. Just disassemble them. Look for abnormalities. Then reassemble them according to the FSM(factory service manual). You could've just overlooked something. It happens.
Alright thanks. I was really hoping I didn't have to replace everything 😂
Old Jul 18, 2017 | 04:25 PM
Atreyu'z 350's Avatar
Atreyu'z 350
No problem. And if disassembling it then reassembling it according to the FSM doesn't fix your issue, then you may have damaged something from over-pressurizing the system when you tried to compress the piston into the bore, like trav said, but at least you eliminate improper assembly by doing this first. Good luck, man.
