Fronts fit on the rear?
Old Sep 5, 2018 | 03:18 PM
Franknbeans's Avatar
Franknbeans
Question Fronts fit on the rear?
Hey guys, I have two set up 35th Anniversary rims. I was considering running all 4 rear rims as my dedicated track rims so I can have a square setup.
This would leave me with 4 front rims as my street rims/tires. Is there any issues of running the smaller front anniversary rims on the rear of the Z?
While swapping tires back to street ones, I put a front rim on the back and "it fit".
Old Sep 5, 2018 | 03:23 PM
KornerCarver's Avatar
KornerCarver
That should work just fine.
Old Sep 5, 2018 | 11:40 PM
terrasmak's Avatar
That would give you a set of 18x8 for street, same as 03-05 18 inch wagon wheels. Then the 18x8.5 will be fine all around.
Warning, those wheels do like to break with heavy use and high heat
Old Oct 26, 2018 | 04:56 PM
Franknbeans
another question. Could I run 245 on the 8" rims?
I picked up some 255 for my 8.5" track rims.
Old Oct 26, 2018 | 05:57 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Sure, 245s are run on the wagon wheel 18s (mentioned above) as stock.
msims
May 15, 2004 11:53 AM
GaryM05
Jun 22, 2003 06:27 PM
