Eastwood fender roller not clearing fender
Old Mar 29, 2021 | 09:03 AM
ghettoscrubs's Avatar
ghettoscrubs
Default Eastwood fender roller not clearing fender
Hi, I have bc extreme low coilovers on and i cannot get the fender roller to fit underneath properly. I've tried extending the coil to max length, i've tried unbolting the lower part of the coilover but that just makes it worse and actually raises the hub higher then what it was fully extended still bolted together. Does anyone have any suggestions on how to get enough clearance?
Old Mar 29, 2021 | 09:23 AM
travlee's Avatar
travlee
Master
pics would help
Old Mar 29, 2021 | 10:05 AM
iideadeyeii's Avatar
iideadeyeii
Swap to stock, roll fenders, swap back
I looked up that tool. Kinda nifty
Old Mar 29, 2021 | 10:22 AM
travlee's Avatar
travlee
Master
thats what AcidJake used to roll my fenders back in the day. after what you said, yeah i guess if he is supper slammed it wouldnt line up, but it should be adjustable from what i remember
Old Jul 29, 2021 | 03:55 AM
bidoulatt's Avatar
bidoulatt
if you dont want to buy one you can find a shop thatll do it cheap, 15 per fender for a cheap place, 150+ for all four at a good place i could be wrong but thats the prices i was told by a friend that had his done, so correct me if i am wrong
Old Jul 29, 2021 | 09:11 AM
GreyZ's Avatar
GreyZ
Are you sure you have the roller adjusted correctly, and have you changed the pivot bolt location? when rolling, you want the hub to be centered in the arch, which is like 25" from fender edge to hub center. If you can get that low, the roller will work.
bomber
Sep 11, 2009 08:32 AM
gunslinger
South West
Aug 28, 2007 09:15 AM
