need help on tires
Old Feb 28, 2004 | 05:23 AM
Gary925's Avatar
Gary925
Default need help on tires
need help!!!
just got a set of LE37 8.5F n 9.5R
i going with 245/35/19 for the front
n 285/30/19 for the rear..
will that be any problem ?
also will i have to roll fender if i lower my z in the further.
Old Feb 28, 2004 | 07:42 AM
Bertg's Avatar
Bertg
Most Z owners here go with 275/35/19 in the rear.
Old Feb 28, 2004 | 08:26 AM
lowrider's Avatar
lowrider
The front tires are fine. The rears may or may not be a problem. The correct size for the rears is 275/35/19. The problem is the overall diameter of the fronts versus the rears. There should be about 1" difference (the rears being larger in OD). In your setup the fronts are 25.8" tall or thereabouts, and the rears are 26" (only .2" larger) the 275/35s on the other hand are 26.7" in OD. You could throw off the VDC (if you have it) or the slip control. Unless you lower, you will also be showing more space between the tire and fender than you would want. As far as fender rolling is concerned, we would have to know the wheel offsets to make a determination on that.
If I were you, I would try and swap the rears for the correct 275/35s.
Lou
Old Feb 28, 2004 | 05:27 PM
Gary925's Avatar
Gary925
Default tire
as wut u suggest ,275/35/19 rear n 245/35/19 front.
im going to lower my z so will tht look just fine rather then using 285/30/19 on rear ..
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
