A really good question to pose...REAd UP!!
Old Mar 19, 2004 | 06:01 PM
zland's Avatar
zland
Sport Z Magazine
Originally posted by azrael
one HUGE fact you guys are forgetting.. i mentioned this in my post above...
It doesn't matter if you have a 15, 16, 17, 18, 19, or 20 inch wheel. The overall diameter of a proper wheel and tire combination is THE SAME. ALWAYS.
When you buy a larger wheel, you choose a tire with a smaller sidewall to compensate.
Bottom's calculations above assume that there is a different rolling diameter, which isn't the case. The difference in acceleration comes from the rotational inertia component of the unsprung wheel/tire mass, which increases with a larger wheel due to weight distribution closer to the edge of the wheel and tire.
Bingo, you hit the nail on the head. Even if the weight of the wheel is equal in both size wheels, the further the weight is towards the outside of the radius, the more negative the effect.
Jeff - zland
PLAYDIRTY
Oct 12, 2015 07:45 AM
etong
Sep 10, 2015 06:14 PM
