spacers on volks?
Old Jul 18, 2004 | 09:47 PM
97 grn ss's Avatar
97 grn ss
Default spacers on volks?
is there any way to use spacers on a +35mm offset Te37 (10.5) to make it fit w/o rubbing on 1 inch drop?
say a 10mm Spacer, would it bring it closer to fender?
or does a 9.5 inch +12 fit w/o rubbing on a very minimal drop?
thanks
Old Jul 18, 2004 | 10:08 PM
HaNkYs_Z's Avatar
HaNkYs_Z
I dont think you will need spacers on 10.5 +35, I dont think it will look tuck in. As for the 9.5 +12, yes, it will rub for sure if you go with Bridgstone SO3 275/35, but if you go with Toyo T1s 275/35 or Bridgstone SO3 275 or 285/30 you should be fine if you dont lower it too much. How low are you going to lower?
Stevo Z
Oct 3, 2015 09:14 PM
