Correct Tire Size for 20x9?
Old Sep 3, 2004 | 09:30 AM
josephl30's Avatar
josephl30
Question Correct Tire Size for 20x9?
Does anyone have this setup....I will be going with a 19x8 and 20x9 and I was thinking a 275\35\20 would be a good fit! If anyone has pics of this setup, I would like to see it!
Old Sep 3, 2004 | 10:16 AM
Type R Boy's Avatar
Type R Boy
Not sure but I would assume that if you are going to go 245-35-19 for your fronts with the 19s then 275-30-20 would be a better/closer fit for the rears.
Old Sep 3, 2004 | 10:59 AM
lowrider's Avatar
lowrider
Type R Boy is correct. 245/35/19s front and 275/30/20 in back will keep the correct stagger with those size wheels. However, you will have some slight tire bulge. The recommended rim widths for a 275/30 is 9.5" to 11". Your combo should probably work OK though.
Lou
Old Sep 3, 2004 | 11:37 AM
josephl30's Avatar
josephl30
Thanks guys....I may get the 20x10 if that would work out better...and yes I planned on going with a 19x8 in the front. AXIS 7 MOD....thanks again!!!!
