Help on tire problem
Old Sep 5, 2004 | 10:04 PM
Binictican's Avatar
Binictican
Default Help on tire problem
I had a right rear flat today. Don't know why yet.
But when you get a flat on a performance car, do you need to replace both rear tires? Only have 5260 miles on the car.
I looked at the tire when I got it off. Couldn't see any punctures, but two spots on the inside sidewall were worn through.
Anyone know of tire interference problems as it is going flat?
Old Sep 5, 2004 | 10:13 PM
AmyCroft's Avatar
AmyCroft
Default Re: Help on tire problem
Example... ( As you gave no history or reason..For your rear tire..)
I had a rear tire with a slow leak.. the tire presure droped to 22 to 25 Lb's..
The tire was broken down to repair the slow leak..
The inner side wall and the tread had rubbed a V grove, nearly to the out side wall.. Glad I never took the car to speed on that tire..
Low pressure and high camber can destroy a tire from the inside.
Cheers Amy -
Uriyo_
Sep 8, 2021 08:46 AM
