Ridiculous Size
Old Oct 12, 2004 | 08:08 PM
tah's Avatar
tah
Default Ridiculous Size
How do you fit 18x9.5 in the front and 18x12 in the rear? What size tires do you use?
Old Oct 12, 2004 | 09:12 PM
Skrill's Avatar
Skrill
Default Re: Ridiculous Size
Umm .... maybe buy a Corvette.
Honestly ... I have 10.5 rears (SSR Comps) -- they sit pretty flush to the outside fender, and have maybe a half inch clearance to the strut. No way 12" rears fit unless you have over an inch of rim sticking out past the fenderline (which would look stupid IMHO).
BTW, I run 265/35 (f) and 295/35 (r).
Old Oct 12, 2004 | 09:23 PM
03Z33's Avatar
03Z33
Like this:
Those are 18x10 et 22 front and 18x12 et22 rear. The trick is to stretch smaller tires, and to run a lot of negative camber.
These had 215/40/18 fronts and 245/40/18 rears. And no I don't drive on these, they where just test fitted for laughs.
BTW these would work fine, if I didn't have Brembos... as they sit on the car the fronts have an 18mm spacer effectively making the front offset +4!
more pics on my cardomain site linked below
Old Oct 13, 2004 | 11:58 AM
bwzabodyn's Avatar
bwzabodyn
That is the dumbest thing I've ever seen - who the hell would want those on their car?!?! That looks like crap!
Old Oct 13, 2004 | 12:09 PM
03Z33's Avatar
03Z33
to each his own... some of the stuff on your car makes me puke.hahaha
Old Oct 13, 2004 | 12:16 PM
Pedal Pusher's Avatar
Pedal Pusher
Skrill.....
With the 265's on the front does the car want to wonder on uneven pavement or two lane country roads? Thanks in advance.
Old Oct 13, 2004 | 07:02 PM
tah's Avatar
tah
And rolling or flaring the fenders wouldnt make it fit?
Old Oct 13, 2004 | 07:18 PM
stu46's Avatar
stu46
Just need the TS Wide Bodykit.
Old Oct 13, 2004 | 08:51 PM
ChuckGZ's Avatar
ChuckGZ
Stu beat me to the punch. that extra 4 cm should set you up.
Old Oct 13, 2004 | 09:51 PM
Skrill's Avatar
Skrill
Originally posted by Pedal Pusher
Skrill.....
I do get a bit of tramlining. But overall the handling is sharpened up a lot.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
