19" FS: SSR GT3 wheels with tires, 19x9 front / 19x10.5 rear
SOLD
It's time for a bit of garage clean out. I have a dozen race tires posted in the competition forum, but I'd also like to trim down the number of wheel sets we have as well. This ad is for the SSR GT3 wheels with gunmetal center portions that were on my wife's ZR for many years. Retail on this set for wheels alone was over $2400 plus tax and install. These wheels look good from 2' away; they are not in perfect condition. Please take a close look at the posted pictures, as I've tried to capture the flaws in each wheel as best as I possibly could. The long, chrome, SSR valvestems were an added option to the tune of about $75, and are included.
The details of the wheels are as follows:
Front: 19x9 +31 with 245/35/19 Toyo Proxy T1-R tires
Rear: 19x10.5 +43 with 275/35/19 Toyo Proxy T1-R tires
$1550 plus actual shipping
The tire condition is documented below. The two fronts have great tread depth across the width, but had some camber wear so I moved them left-to right / right-to-left so that the old inside is now on the outside, and vice-versa. One rear has slightly more tread than the other. The rears are certainly good enough for some mileage, but they may need replacing relatively soon. I used to run 305/30/19s on these rears and 275/30/19 then 265/35/19s on the front without issue - that's the beauty of the high offset wheel. I ran the 305 with a 15mm spacer. The spacer was not necessary on our stock-suspension Z, but when I put them on my track car, the spacer was required (for the 305s) since the tire hit the barrel of the TEIN shock in the rear.
A few overall pictures on the car are posted in active links below as well as the attachments in this post.
Wheels on the old and new ZR (with 255 front and 15mm spacer and 285 rear with 20mm spacer)
15, 20, and/or 25mm spacers are available for an additional cost if you'd like them, though they are not necessary for fitment for $90/pair.
Asking $1600 plus actual shipping. Look at my iTrader - I have shipped literally dozens of sets of wheels, tires, or wheel/tire combos. I have it down to a science, and shipping is not a problem. Cross-country shipping to a residence, with insurance, will cost about $180. I accept PayPal if you cover the fee or send the $ as a gift or money owed. Alternatively, you can send a PayPal deposit and the balance by check or money order. I am open to options, as I'd like to see these go to a good home.
Spring clean out:
15mm H&R spacers used in the front:
The wife's ZR with the new (but used) wheels (for simple credibility):
SSRs on the "old" ZR - no spacers:
265/35/19 front with 305/30/19 rear on my track car (Before it was green):
Old set-up:
275/30/19 front on a 19x9 +31 (no spacer)
305/30/19 rear on a 19x10.5 +28 (15mm spacer)
Never any rubbing, even under full compression, and no fenders rolled
Spring clean out:
Old set-up:
That's not including the set ON my track car.
I couldn't photograph those since I keep the car elsewhere.
Thanks!
I couldn't photograph those since I keep the car elsewhere.Thanks!
hey Scott do you have a set of (4) 18x9.5 black RPF1's?
I'm looking for change in setup and still wanna use my current 265/40/18 RE-11's.
If so can you pm me a price shipped to 48108.
Thanks man!
Thanks man!
Thanks!
