FS: ** USED Ichiba 5MM Hubcentric Aluminum Wheel Spacers **
SOLD THANK YOU
Description:
Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Spec:
Bolt Pattern: 5/114.3
Center Bore: 66.2
Sold as two pairs (4pcs).
These are used but in excellent condition.
Description:
Spec:
Center Bore: 66.2
